Inter Vlan routing problem
Attila123
Hello Everyone,
I have an IT testlab with a Cisco 880 VA router. It has 4 switchports (FA0-3). I use these switchports only, as for some reason I can't configure the atm/eth0 port.
Configuration: I have got two Vlans: Vlan1 and Vlan2. FA/1, FA/2, FA/3 are parts of Vlan1 a local LAN. Vlan1 has got a permanent IP address, configured by a dhcp server.
FA/0 is part of Vlan2 and Vlan2 has got a static IP address.
I configured static route from Vlan1 network using Vlan2 ip address as exit interface and also a static route from Vlan2 network using Vlan1 ip address as exit interface. But it doesn't work and I don't understand why. I read through L3 switching and router on the stick, but they don't seem to apply for this scenario.
Can someone help me please?
Thank you,
Attila
Show Run Full
version 15.7
no service pad
service password-encryption
no aaa new-model
memory-size iomem 10
ip cef
no ipv6 cef
license udi pid CISCO887VA-M-K9 sn FCZ164690P4
controller VDSL 0
interface Ethernet0
no ip address
shutdown
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
switchport access vlan 2
switchport mode access
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address dhcp
interface Vlan2
ip address 192.168.20.2 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 192.168.10.0 255.255.255.0 Vlan2
ip route 192.168.10.0 255.255.255.0 192.168.20.1
ip route 192.168.20.0 255.255.255.0 Vlan1
ipv6 ioam timestamp
control-plane
vstack
 Show IP route
Gateway of last resort is not set
192.168.10.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.10.0/24 is directly connected, Vlan1
L 192.168.10.3/32 is directly connected, Vlan1
192.168.20.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.20.0/24 is directly connected, Vlan2
L 192.168.20.2/32 is directly connected, Vlan2
Show int Vlan1
Vlan1 is up, line protocol is up
Hardware is EtherSVI, address is e4d3.f168.b328 (bia e4d3.f168.b328)
Internet address is 192.168.10.3/24
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive not supported
Last input 00:50:24, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
1100 packets input, 91268 bytes, 0 no buffer
Received 896 broadcasts (0 IP multicasts)
124 packets output, 26828 bytes, 0 underruns
0 output errors, 1 interface resets
135 unknown protocol drops
Show int Vlan2
Vlan2 is up, line protocol is up
Internet address is 192.168.20.2/24
Last input 01:14:17, output never, output hang never
597 packets input, 85153 bytes, 0 no buffer
Received 426 broadcasts (10 IP multicasts)
32 packets output, 3174 bytes, 0 underruns
11 unknown protocol drops
Attila
Thanks for the update. Glad to know that you have it working now. The fact that the solution was to stop using DHCP on the win server and implement it on the router confirms my suggestion that your router configs were ok and that the problem was something on the hosts.
It is good that you learned a lot doing this. I hope you will continue to learn about routing and switching and continue to be active in the community.
Rick
15 Replies 15
Georg Pauwen
make sure Vlan 2 actually exists on your router. You need to manually create it:
880#conf t
880(config)#vlan 2
Thank you, I have already created, but vlans don't seem to access each other.
If it is not working I would suggest these things to do:
- post current config
- from the device in vlan 2
-- can it ping the vlan 2 IP address
-- can it ping the vlan 1 IP address
-- can it ping the device in vlan 1
- from the device in vlan 1
-- can it ping the device in vlan 2
If it does not work this process should show where it is breaking down.
Rick
I don't want to ask redundant questions in addition to Rick's remarks, but can you see both Vlan interfaces when you do a 'show ip route' ? Can you ping the IP addresses of both interfaces from the router itself ?
Richard Burts
There are several issues with the routing statements that you have configured.
You have 2 route statements for the subnet of vlan 1. I am not sure why. And both of them are not correct. In effect both of them say that we should get to vlan 1 by going to vlan 2.
You have 1 route statement for the subnet of vlan 2. And it says that to get to vlan 2 we should go to vlan 1
Both of these subnets are locally connected and as such do not need any route statements. As currently configured the device in vlan 2 should be able to access all devices in vlan 1. And the devices in vlan 1 should be able to access the device in vlan 2. None of the devices would be able to access outside resources (and that probably will be resolved as you figure out how to configure and use the Ethernet/atm interface(s)+.
Rick
Thank you Rick for taking time to look into my config. :)
My problem is when I try to ping devices in vlan 1 from vlan 2 I get100% packet loss, and vica-versa. Meaning I have a device in vlan2 with ip address 192.168.20.1 and when I try to ping for example 192.168.10.1 (which is the dhcp server in Vlan1) 100% loss. When I try to ping 192.168.10.3 (which is the ip of Vlan1) also 100% loss and it says I can't ping the router itself. So it seems like they don't see each other, or I'm very confused.
I am not sure you posted the entire config, but I think by default the router has 'no ip routing' configured, make sure you have that enabled globally (ip routing):
880#conf t
880(config)#ip routing
That said, where are you pinging from, and what default gateway do your clients have configured ?
Hello
Just like to ask - Have you created vlan 2 in the vlan database otherwise you wouldnt get connectivity between vlan1 -2
conf t
vlan 2
exit
Lasty as suggested by Rick, remove the static routes as they are not required inter-vlan communication
Kind Regards
Paul
Attila
If the devices in vlan 1 and 2 are PCs would you post the output of ipconfig (and if not PCs then the output of the appropriate command to display their IP address, mask, and default gateway)? Also please try the ping again and then immediately do arp -a (or other appropriate command to show the arp table) and post that output.
Also would you post the output on the router to the command show arp.
Rick
Dear Gentlemen,
I have attached my full network infrastructure to this message. I'm sorry I can't make png or jpg posted here.
This is the full config and pings belong to the network. With your suggestions I have solved most of the problems. The only thing I don't understand is why I can't ping from Router1, or Router2 into the 192.168.10.0 network, although from the DHCP server of this network I can ping all the router interfaces,  including 192.168.0.47, which is the interface to the network of the ISP-s router.
Thank you for your help and insight.
Kind regards,
Attila
Router 1 show run full (sh run conf doesn't work)
Current configuration : 1315 bytes
version 15.3
no service pad
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
controller VDSL 0
interface Ethernet0
no ip address
shutdown
interface ATM0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip address dhcp
interface Vlan2
ip address 192.168.20.1 255.255.255.0
no ip http server
ip route 192.168.10.0 255.255.255.0 192.168.20.2 150
Router 1 pings
ping 192.168.0.1
Sending 5, 100-byte ICMP Echos to 192.168.0.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/6/12 ms
ping 192.168.0.47
Sending 5, 100-byte ICMP Echos to 192.168.0.47, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
ping 192.168.20.1
Sending 5, 100-byte ICMP Echos to 192.168.20.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
ping 192.168.20.2
Sending 5, 100-byte ICMP Echos to 192.168.20.2, timeout is 2 seconds:
ping 192.168.10.3
Sending 5, 100-byte ICMP Echos to 192.168.10.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/3/12 ms
ping 192.168.10.1
Sending 5, 100-byte ICMP Echos to 192.168.10.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
ping 192.168.10.2
Sending 5, 100-byte ICMP Echos to 192.168.10.2, timeout is 2 seconds:
Router 2 show run full
Current configuration : 1493 bytes
version 15.7
no service pad
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
controller VDSL 0
interface Ethernet0
no ip address
shutdown
interface ATM0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip address dhcp
interface Vlan2
no ip http server
ip route 0.0.0.0 0.0.0.0 192.168.20.1
ip route 192.168.0.0 255.255.255.0 192.168.20.1
ipv6 ioam timestamp
control-plane
vstack
Router 2 Pings
ping 192.168.10.1
ping 192.168.10.2
ping 192.168.10.3
ping 192.168.20.2
ping 192.168.20.1
ping 192.168.0.47
ping 192.168.0.1
ping 192.168.0.28
Sending 5, 100-byte ICMP Echos to 192.168.0.28, timeout is 2 seconds:
Attila
The original post was about attempting ping between devices on 2 vlans on a single router. Now we are discussing ping  where there are 2 routers, 2 LAN subnets, and a transit vlan. That is a significantly different environment.
I have looked at the posted configs and do not see any significant issues in them. (we might talk about the fact that the static route for 192.168.0.0 on router 2 is not needed - but that is not important to your real question here). I see that router 1 pings are successful for every destination except for 192.168.10.1 and 192.168.10.2. And I see that router 2 pings are successful except for the same 2 destinations. So I believe that the problem here is not at all related to the router configurations. I believe that the router configurations are quite acceptable.
If a ping from the router interface to a locally connected device fails then it is not a routing issue. Perhaps there is something like a firewall running on these devices (or some other type of security environment) that does not allow ping? Or perhaps there is some other issue?
If you are sure that there is no firewall or other security restriction on those devices then we need to investigate further. Please post from the router the output of show interface vlan 1 and of show arp. From the devices please post the output of ipconfig and of arp -a (or other appropriate commands if they are not Windows devices).
Rick
Hello Richard, George and Paul,
I finally disabled dhcp on the win server and I configured Router2 as a dhcp server and set dna on the nics. It all solved my problems. Thank you very much for your time and effort.
I learnt a lot about switching and routing in the last few days.
Best Regards,
Attila
Attila
Rick
Hello Paul,
Thank you for your time.
Yes, I have created VLAN 2 and deleted unnecessary routes.
I post my full configuration with the network infrastructure below.
Kind regards,
Attila
