Inter vlan
kabilanvijay8
L3 switch has two VLAN's , vlan 1 with ip address of 192.168.1.1 and vlan 10 with ip address of 192.168.10.1 assigned in the switch .
when the cable connected from the device in vlan 10 to the port is removed from the switch
why cant we ping the ip of vlan 10 which is present in the switch from the device connected to vlan 1 ?
can someone give me the reason please...
10 Replies 10
Hi @kabilanvijay8
 Make sure you enabled routing on the switch
conf t
 ip routing
If you did, make sure both hosts have default gateway configured.
I have  done it all bro
If you have ip routing enable, if you have default gateway pointing to the interface vlan on the switch, if you added the vlan to the switch port where the host is connected, the only thing I can think of is firewall on the PC bloking the ping.
share
show vlan
show ip in breif
show ip route
VLAN 1 - IP Gateway address 192.168.1.1 ; Device IP - 192.168.1.10
VLAN 10 - IP Gateway address 192.168.10.1 ; Device IP - 192.168.10.10
Note: Gateway IP address in assigned in switch
Device in VLAN 1 is connected in port no 01
Device in VLAN 10 is connected in port no 22
my question is , when I remove the cable from the port 01 ,why can't I ping the gateway of VLAN 1 from the device in VLAN 10 ?
that normal,
VLAN need one port UP to be UP/UP
some switch have no autostate comamnd to override this issue
OR
allow vlan in trunk UP port
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/41141-188.html
RoadRunner4k
is the vlan 10 in up/up state ?  (did you make vlan 10 also?)
show interface vlan 10
Vlan10 is up, line protocol is up
Hardware is EtherSVI, address is 4c00.828f.76c1 (bia 4c00.828f.76c1)
Internet address is 192.168.10.1/24
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not supported
Last input 00:01:31, output 00:17:35, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
2545 packets input, 263461 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
1495 packets output, 128043 bytes, 0 underruns
0 output errors, 3 interface resets
0 unknown protocol drops
show ip int brief <<- share this
show ip route <<- share this
kabilanvijay8
