Inter-VRF Port Forwarding
Cory Anderson
I have a scenario where there's a single router with a WAN interface using a front door VRF. The internal host 192.168.1.10 is a web server and I want to port forward port 8080 to port 80. I thought something like this would be okay, but I'm having no luck. Anybody know what I'm missing?
interface G0
  ip vrf forwarding EXT_VRF
  ip address negotiation
  ip nat outside
interface vlan 10
  ip address 192.168.10.1 255.255.255.0
  ip nat inside
ip nat inside source static tcp 192.168.1.10 80 interface g0 8080 vrf EXT_VRF
ip route 0.0.0.0 0.0.0.0 g0
ip route vrf EXT_VRF 192.168.1.10 255.255.255.0 vlan10
What is router platform you use ?
MHM
@Cory Anderson
 You are using 192.168.10.1 on the interface vlan and 92.168.1.10 on the NAT and route. Which is which?
Cristian Matei
    Out of curiosity, for which specific scope you're using VRF lite? I don't know the entire router config, so there might be valid reasons, however, if it's not the case, ideally you should avoid such complications.
    Now, moving to the presented challenge, a working config would be as follows:
interface G0
  ip nat outside
interface vlan 10
  ip nat inside
no ip route 0.0.0.0 0.0.0.0 g0
ip route 0.0.0.0 0.0.0.0 g0 NEXT-HOP-IP
ip route 192.168.1.0 255.255.255.0 Vlan10 NEXT-HOP-IP
no ip route vrf EXT_VRF 192.168.1.10 255.255.255.0 vlan10
ip route vrf EXT_VRF 192.168.1.10 255.255.255.0 vlan10 NEXT-HOP-IP global
ip route vrf EXT_VRF 0.0.0.0 0.0.0.0 g0 NEXT-HOP-IP
no ip nat inside source static tcp 192.168.1.10 80 interface g0 8080 vrf EXT_VRF
Best,
Cristian.
