405
Highlighted
Beginner
Inter VRF Route Leaking
Nevermind - reboot of the routers did the trick.
If I was able to delete this post I WOULD HAVE :-)
2 REPLIES 2
Highlighted
Hall of Fame Master
Hello @bart.dermul1 ,
good news that you have been able to solve this issue
Best Regards
Giuseppe
Highlighted
YES - it sounds stupid, but I just did a reboot. I did notice that this was mainly the effect by using the 'clear ip bgp * ' process. On a own LAB test this is not such a big deal. But it was in the end. A soft reset did not produce this problem anymore !
But thank you for the explanation.
Wish you all the best
