Interet ISP redirecting all websites to different region
santoshdpawar
Hi Guys,
I have been facing issue with internet being redirecting to other region (US to Brazil). ISP is unable to comment and still working on this. WHOIS provides correct location of the source IP ( my WAN IP provided by ISP) and the trace to redirected websites (IP's found using nslookup) provides no much useful info and are showing correct region.
Anything we can do from LAN PC's to pin point the issue to ISP? Also is there anything to do with ISP DNS ? Google gets redirected to google Brazil which is due to regional settings at Google ?
Best regards,
Santosh Pawar
santoshdpawar
Guys,
41 post views but no post reply
Lei Tian
Hi Santosh Pawar,
Does it redirect you if you use IP instead hostname for web? I am not positive, but I think google could redirect based on your language preference setting.
HTH,
Lei Tian
Hi Lei Tian,
We finally got the root cause. This is resolved. Thanks for your support.
