Interface atm crc error
rleung2001
I have a question about the different between 2 crc errors
ADSL circuit has packet loss, when I enter show dsl int atm 0/0/0.
The crc Errors and Header Errors are 0.
This is good.
When I enter show inter atm 0/0/0.
The crc value is incrementing when packet loss occurred.
What is/are the differece between 2 crc?
purohit_810
Level 5
Level 5
Crc occur most of the reason, Physical layer issue. You can follow this link for step by step troubleshooting.
http://www.cisco.com/en/US/tech/tk39/tk48/technologies_tech_note09186a00800c93ef.shtml
Make sure, your cable is good,
Make sure your modem is configured good,
Check link releibility " Show interface " command.
check utilization of Link by " Show interface "
Dharmesh Purohit
bill.morton
The other day while troubleshooting I had a DSL circuit that had huge CRC and header errors on the sh dsl interface atm0/0/0; it ended up being the providers circuit. SNR went from 9db to 19db after they 'cleaned' the circuit and errors went away.
Do you have a spare WIC to test?
