Interface cellular0/2/0 doesn't get an IP and come up
Onrcan91
controller Cellular 0/2/0
 no lte firmware auto-sim
 lte modem link-recovery disable
interface Cellular0/2/0
 ip address negotiated
 dialer in-band
 dialer idle-timeout 30
 dialer-group 1
 pulse-time 1
Hi everyone,i couldn't get an IP address for Cellular 0/2/0 on Cisco ISR 1117,i am new to ISR 1100 series,i've worked with ISR800 so far.Now it's time to configure ISR1100 let me share cellular interface with all of you.What's wrong here ?
testturcom-bp#sh cellular 0/2/0 all
Hardware Information
Modem Firmware Version = SWI9X30C_02.20.03.00
Device Model ID =  EM7455
International Mobile Subscriber Identity (IMSI) = 286016248571686
International Mobile Equipment Identity (IMEI) = 356129070387359
Integrated Circuit Card ID (ICCID) = 8990011703030116867
Mobile Subscriber Integrated Services
Digital Network-Number (MSISDN) =
Factory Serial Number (FSN) = LF847396280210
Modem Status = Modem Online
Current Modem Temperature = 35 deg C
PRI SKU ID = 1102526, PRI version = 002.017_001, Carrier = GENERIC
OEM PRI version = 000.007
Profile Information
Profile 1 = INACTIVE* **
PDP Type = IPv4
Access Point Name (APN) = bpsite
Authentication = CHAP
Username =  testturcombp-istanbul
Password =  1113
  * - Default profile
 ** - LTE attach profile
Configured default profile for active SIM 0 is profile 1.
Data Connection Information
Profile 1, Packet Session Status = INACTIVE
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current System Time = Mon Mar 9 14:14:16 2020
Current Service Status = Normal
Current Service = Packet switched
Current Roaming Status = Home
Network Selection Mode = Automatic
Network = TR TURKCELL
Mobile Country Code (MCC) = 286
Mobile Network Code (MNC) = 1
Packet switch domain(PS) state = Attached
LTE Carrier Aggregation state = Deconfigured
Registration state(EMM) = Registered
EMM Sub State = Normal Service
Tracking Area Code (TAC) = 5891
Cell ID = 1173536
Network MTU is not Available
Radio Information
Radio power mode = online
LTE Rx Channel Number =  1651
LTE Tx Channel Number =  19795
LTE Band =  3
LTE Bandwidth = 20 MHz
Current RSSI = -33 dBm
Current RSRP = -64 dBm
Current RSRQ = -5 dB
Current SNR = 30.0  dB
Physical Cell Id = 500
Number of nearby cells = 2
Idx      PCI (Physical Cell Id)
1              500
2              254
Radio Access Technology(RAT) Preference = AUTO
Radio Access Technology(RAT) Selected = LTE
Modem Security Information
Active SIM = 0
SIM switchover attempts = 0
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of CHV1 Retries remaining = 3
Cellular Firmware List
 Idx Carrier      FwVersion    PriVersion   Status
 1   ATT          02.20.03.00  002.020_000  Inactive
 2   BELL         02.20.03.00  000.010_000  Inactive
 3   GENERIC      02.20.03.00  002.017_001  Active
 4   ROGERS       02.20.03.00  000.011_000  Inactive
 5   SPRINT       02.20.03.22  002.020_000  Inactive
 6   TELUS        02.20.03.00  000.011_000  Inactive
 7   US-Cellular  02.24.05.06  000.003_000  Inactive
 8   VERIZON      02.20.03.22  002.026_001  Inactive
 9   VODAFONE     02.24.03.00  001.001_000  Inactive
Firmware Activation mode  =  MANUAL
AVMS FOTA Information
AVMS FOTA is not enabled
GPS Information
GPS Feature =  enabled
GPS Mode Configured =  not configured
GPS Status =  NMEA Disabled
SMS Information
Incoming Message Information
SMS stored in modem = 0
SMS archived since booting up = 0
Total SMS deleted since booting up = 0
Storage records allocated = 25
Storage records used = 0
Number of callbacks triggered by SMS = 0
Number of successful archive since booting up = 0
Number of failed archive since booting up = 0
Outgoing Message Information
Total SMS sent successfully = 0
Total SMS send failure = 0
Number of outgoing SMS pending = 0
Last Outgoing SMS Status = SUCCESS
Copy-to-SIM Status =     0x0
Send-to-Network Status = 0x0
Report-Outgoing-Message-Number:
  Reference Number =     0
  Result Code =          0x0
  Diag Code =            0x0 0x0 0x0 0x0 0x0
SMS Archive URL =
Modem Crashdump Information
Modem crashdump logging = off
post the full running configuration (show run) of the ISR...
testturcom-bp#sh run
Building configuration...
Current configuration : 11013 bytes
! Last configuration change at 14:31:37 UTC Mon Mar 9 2020 by turcom
version 16.9
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname testturcom-bp
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$3npH$9GjZeVJJlk2fA/Hrdh8m1/
aaa new-model
aaa authentication login default local
aaa session-id common
ip name-server 195.175.39.39 195.234.52.100 195.87.102.18
ip domain name bp.com.tr
login on-success log
subscriber templating
crypto pki trustpoint TP-self-signed-2458016171
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2458016171
 revocation-check none
 rsakeypair TP-self-signed-2458016171
crypto pki certificate chain TP-self-signed-2458016171
 certificate self-signed 01
  30820330 30820218 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32343538 30313631 3731301E 170D3230 30333039 31313532
  33395A17 0D333030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 34353830
  31363137 31308201 22300D06 092A8648 86F70D01 01010500 0382010F 00308201
  0A028201 0100E8F7 BEFD31B5 15F97677 BBECF3BF A8462F14 2CFAB19E 42587A0C
  0E36E5CC BBD4F49D 09A7BB8B F82C9A65 39F085C1 C9546BB4 A97FF8F3 A901AC1B
  414D8A44 14450B05 1656911C DE276E6B A1199EE9 FFFF3170 4D99005D 40CCB141
  B08A3CD5 9E0E38C7 02B93FFE F55CA74D D1F83C79 D7DAE2BA BBCD72FB A98C3899
  75353749 23D570AC 5834DA4D 0366CCF5 929216C1 298F098D 18820079 9CAC7A74
  BF3007CD 89B308B2 C54FE784 5C82C066 16AEA6B0 32DD1069 D4F3BAC6 FE4B376C
  9F551C88 8193719F 529747E5 DF220E2A BF84448B E22C5434 4773CB0E F970DEA0
  5F3131EB 38783D1E 1A71CACD 7C22C9CA 163D0524 23E18016 143D08AC 63FA78BE
  3F34E4FB AA7B0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF
  301F0603 551D2304 18301680 1476C11D 1F860C71 560CF2B3 CB177F06 1E9B6986
  06301D06 03551D0E 04160414 76C11D1F 860C7156 0CF2B3CB 177F061E 9B698606
  300D0609 2A864886 F70D0101 05050003 82010100 DFA4B6F9 BFC5201B DCB48A39
  1770B87E 555915A2 2CBE57B1 DF65C1AD EFBAB8BF 1B50B3BD FA7F3036 77FE0481
  81915EC1 32CA491F 23E01E80 4BF5BF1D 3B004821 C3254518 1CB4B942 9C5CB4CC
  C728D05F A5430CF7 703A8093 C16D59CF 5206F1E6 774C124C 8E168A48 C2C7086F
  E90AB3B1 4B40D1E0 88959192 830BE830 00B428D0 C58B83D3 618B4274 0DA508A8
  91BAFBF2 CB26131D 66B68FDB C2F672AB 9CD4563A 26E9094C 4F5F0558 AA6407CC
  73AAD2A9 1CC9EBCC B4D46BD0 39BC533D C0DF3F10 5ADB4B2C 01B20827 74657FCD
  7CDAF5DB 9677B711 A1D3AC7A 6ECE92E6 FFA521D2 E3DDD15D 660A09EF EA83B16D
  A6618704 897A1377 11434EBB 1C140E0C E3DE1D97
        quit
license udi pid C1117-4PLTEEA sn FGL230111DP
license accept end user agreement
license boot level securityk9
no license smart enable
diagnostic bootup level minimal
username turcom secret 5 $1$R5cw$mK7w8rhHK3hyyvpDkR.zb/
redundancy
 mode none
controller VDSL 0/3/0
vlan internal allocation policy ascending
crypto keyring VPNbp
  pre-shared-key address 185.197.125.2 key turcomturcom
crypto isakmp policy 1
 hash md5
 authentication pre-share
 group 2
 lifetime 28800
crypto isakmp fragmentation
crypto isakmp nat keepalive 20
crypto isakmp profile bp-isakmp-profile
   keyring VPNbp
   self-identity user-fqdn testturcombp_istanbul@bp.com.tr
   match identity address 185.197.125.2 255.255.255.255
   keepalive 3600 retry 2
   initiate mode aggressive
crypto ipsec transform-set des-md5-prof esp-des esp-md5-hmac
 mode tunnel
crypto ipsec profile bp-profile
 set transform-set des-md5-prof
 set pfs group2
 set isakmp-profile bp-isakmp-profile
interface Tunnel1
 backup delay 10 10
 backup interface Tunnel2
 ip address 10.180.103.152 255.255.248.0
 tunnel source Dialer1
 tunnel destination 185.197.125.2
 tunnel path-mtu-discovery
 tunnel protection ipsec profile bp-profile
interface Tunnel2
 ip address 10.180.99.152 255.255.248.0
 ip access-group 122 in
 tunnel source Cellular0/2/0
interface GigabitEthernet0/0/0
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
 dialer in-band
 dialer-group 1
 pulse-time 1
interface Cellular0/2/1
 no ip address
 shutdown
interface ATM0/3/0
 no ip address
 atm oversubscribe factor 2
 no atm ilmi-keepalive
 no atm enable-ilmi-trap
interface ATM0/3/0.1 point-to-point
 pvc 8/35
  no broadcast
  encapsulation aal5snap
  pppoe-client dial-pool-number 1
interface Ethernet0/3/0
 no ip address
 no negotiation auto
interface Vlan1
 ip address 10.103.152.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly
interface Dialer1
 bandwidth 512
 ip nat outside
 encapsulation ppp
 ip tcp adjust-mss 1300
 dialer pool 1
 dialer-group 1
 ppp authentication pap chap callin
 ppp chap hostname 2122860359@telnet
 ppp chap password 0 2860359
 ppp pap sent-username 2122860359@telnet password 0 2860359
 ppp multilink
 ppp multilink interleave
 ppp multilink fragment delay 10
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source list 101 interface Dialer1 overload
ip route 185.197.125.254 255.255.255.255 Dialer1 track 1
ip route 172.45.1.1 255.255.255.255 Cellular0/2/0 track 2
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Cellular0/2/0 100
ip route 10.0.0.0 255.255.252.0 Tunnel1
ip route 10.0.0.0 255.255.252.0 Tunnel2 10
ip route 10.20.0.0 255.255.255.0 Tunnel1
ip route 10.20.0.0 255.255.255.0 Tunnel2 10
ip route 10.24.160.0 255.255.255.0 Tunnel1
ip route 10.24.160.0 255.255.255.0 Tunnel2 10
ip route 10.90.0.0 255.255.0.0 Tunnel1
ip route 10.90.0.0 255.255.0.0 Tunnel2 10
ip route 10.90.4.253 255.255.255.255 Cellular0/2/0
ip route 10.129.0.24 255.255.255.255 Tunnel1
ip route 10.129.0.24 255.255.255.255 Tunnel2 10
ip route 10.129.0.48 255.255.255.255 Tunnel1
ip route 10.129.0.48 255.255.255.255 Tunnel2 10
ip route 10.129.0.50 255.255.255.255 Tunnel1
ip route 10.129.0.50 255.255.255.255 Tunnel2 10
ip route 10.129.0.91 255.255.255.255 Tunnel1
ip route 10.129.0.91 255.255.255.255 Tunnel2 10
ip route 10.129.0.113 255.255.255.255 Tunnel1
ip route 10.129.0.113 255.255.255.255 Tunnel2 10
ip route 10.222.7.0 255.255.255.0 Tunnel1
ip route 10.222.7.0 255.255.255.0 Tunnel2 10
ip route 64.90.123.0 255.255.255.0 Tunnel1
ip route 64.90.123.0 255.255.255.0 Tunnel2 10
ip route 102.90.8.0 255.255.255.0 Tunnel1
ip route 102.90.8.0 255.255.255.0 Tunnel2 10
ip route 106.90.8.0 255.255.255.0 Tunnel1
ip route 106.90.8.0 255.255.255.0 Tunnel2 10
ip route 149.195.174.0 255.255.255.0 Tunnel1
ip route 149.195.174.0 255.255.255.0 Tunnel2 10
ip route 149.195.188.0 255.255.255.0 Tunnel1
ip route 149.195.188.0 255.255.255.0 Tunnel2 10
ip route 172.16.209.0 255.255.255.0 Tunnel1
ip route 172.16.209.0 255.255.255.0 Tunnel2 10
ip route 172.16.214.240 255.255.255.240 Tunnel1
ip route 172.16.214.240 255.255.255.240 Tunnel2 10
ip route 172.17.21.0 255.255.255.252 Tunnel1
ip route 172.17.21.0 255.255.255.252 Tunnel2 10
ip route 192.168.1.0 255.255.255.0 Tunnel1
ip route 192.168.1.0 255.255.255.0 Tunnel2 10
ip route 192.168.6.0 255.255.255.0 Tunnel1
ip route 192.168.6.0 255.255.255.0 Tunnel2 10
ip route 192.168.51.34 255.255.255.255 Tunnel1
ip route 192.168.51.34 255.255.255.255 Tunnel2 10
ip route 192.168.101.0 255.255.255.0 Tunnel1
ip route 192.168.101.0 255.255.255.0 Tunnel2 10
ip route 193.29.161.0 255.255.255.0 Tunnel1
ip route 193.29.161.0 255.255.255.0 Tunnel2 10
ip route 193.29.163.0 255.255.255.0 Tunnel1
ip route 193.29.163.0 255.255.255.0 Tunnel2 10
ip route 193.254.252.1 255.255.255.255 Dialer1 permanent
ip route 212.115.3.132 255.255.255.255 Tunnel1
ip route 212.115.3.132 255.255.255.255 Tunnel2 10
ip route 213.155.115.58 255.255.255.255 Tunnel1
ip route 213.155.115.58 255.255.255.255 Tunnel2 10
ip route 213.155.115.59 255.255.255.255 Tunnel1
ip route 213.155.115.59 255.255.255.255 Tunnel2 10
ip route 213.248.161.34 255.255.255.255 Tunnel1
ip route 213.248.161.34 255.255.255.255 Tunnel2 10
ip route 217.169.195.17 255.255.255.255 Tunnel1
ip route 217.169.195.17 255.255.255.255 Tunnel2 10
ip ssh time-out 60
ip ssh authentication-retries 2
ip sla 2
 icmp-echo 193.254.252.1 source-interface Dialer1
 frequency 120
ip sla schedule 2 life forever start-time now
ip sla 3
 icmp-echo 172.45.1.1 source-interface Cellular0/2/0
 frequency 120
ip sla schedule 3 life forever start-time now
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 5 permit 84.17.79.0 0.0.0.255
access-list 5 permit 193.254.252.0 0.0.0.255
access-list 8 permit 10.90.0.0 0.0.255.255
access-list 8 permit 193.254.252.0 0.0.0.255
access-list 8 permit 84.17.84.160 0.0.0.7
access-list 8 permit 102.90.8.0 0.0.0.255
access-list 8 permit 10.103.152.0 0.0.0.255
ip access-list extended 100
 permit ip 0.0.0.0 255.255.255.0 any
ip access-list extended 101
 permit udp 10.103.152.0 0.0.0.255 any eq domain
 permit tcp 10.103.152.0 0.0.0.255 host 195.234.52.15 eq www
 permit tcp 10.103.152.0 0.0.0.255 host 88.255.65.196 eq www
ip access-list extended 122
 deny   icmp any host 10.180.102.111
 permit ip any any
control-plane
line con 0
 transport input none
 stopbits 1
line vty 0 4
 access-class 8 in
 password 7 00100614075406
 transport input all
event manager applet ADSL-DOWN
 event track 1 state down
 action 1.0 cli command "enable"
 action 1.1 cli command "configure term"
 action 1.2 cli command "no ip route 0.0.0.0 0.0.0.0 Dialer1"
 action 1.3 puts "ADSL baglantisi koptu"
event manager applet ADSL-UP
 event track 1 state up
 action 1.2 cli command "ip route 0.0.0.0 0.0.0.0 Dialer1"
 action 1.3 puts "ADSL baglantisi geldi"
 action 1.4 puts "clear crypto session"
event manager applet 3G
 event timer watchdog time 2
 action 1.1 cli command "enable"
 action 1.2 cli command "ping 172.45.1.1 source cellular 0/2/0 repeat 2"
event manager applet 3G-DOWN
 event track 2 state down
 action 1.1 cli command "conf t"
 action 1.2 cli command "service internal"
 action 1.3 cli command "exit"
 action 1.4 cli command "test cellular 0 modem-reset"
 action 1.5 puts "3G modem restart edildi"
end
make the changes/additions marked in bold:
version 16.9
boot-start-marker
boot-end-marker
no logging console
aaa new-model
quit
redundancy
mode none
--> lte sim data-profile 1 attach-profile 1
--> lte gps mode standalone (optional/toggle these values)
--> lte gps nmea (optional/toggle these values)
hash md5
group 2
lifetime 28800
keyring VPNbp
mode tunnel
set pfs group2
interface Tunnel1
backup delay 10 10
interface Tunnel2
no ip address
shutdown
negotiation auto
dialer in-band
dialer watch-group 1
dialer-group 1
pulse-time 1
no ip address
shutdown
interface ATM0/3/0
no ip address
pvc 8/35
no broadcast
no ip address
no negotiation auto
interface Vlan1
ip nat inside
interface Dialer1
bandwidth 512
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp multilink
no ip http server
--> dialer watch-list 1 ip 8.8.8.8 255.255.255.255
-> dialer-list 1 protocol ip permit
ip ssh time-out 60
ip sla 2
frequency 120
ip sla 3
frequency 120
permit ip any any
control-plane
line con 0
stopbits 1
line vty 0 4
access-class 8 in
transport input all
end
It can't still get any IP even the protocol and physical status are up and up.
