09-15-2021 03:18 AM - edited 09-15-2021 04:09 AM
I got a problem on a switch, i have an interface TE who are in a suspend mode.
When i check the configuration on Po and on both interface, the configuration is the same...
L2 Switch error log : Te2/1/4 is not compatible with Te1/1/3 and will be suspended (Storm-control Action of Te2/1/4 is SHUTDOWN,SEND TRAP, Te1/1/3 is SEND TRAP,)
L3 Switch error log : Te2/0/3 suspended: LACP currently not enabled on the remote port.
See the configuration below :
On L2 Switch :
On L3 Switch :
interface Port-channel33
description *** TO Po1 - L2 Switch ***
switchport trunk allowed vlan 182,201,353,402,407-410,424,435,454
switchport mode trunk
switchport nonegotiate
ip arp inspection trust
logging event trunk-status
carrier-delay msec 0
storm-control broadcast level 1.00
storm-control action trap
interface TenGigabitEthernet1/0/3
description *** TO Te1/1/3 - L2 Switch ***
channel-group 33 mode active
interface TenGigabitEthernet2/0/3
description *** TO Te2/1/4 - L2 Switch ***
I have 3 switch stacks configured like this and i got the problem on only 1...
09-15-2021 05:01 AM
Hello @Dimitri.F ,
try the following:
shutdown both member links and po1 interface on L2 switch
remove storm-control configuration ( disable it ) on both member links and on the po1
unshut the port-channel
unshut the member links ( ideally at the same)
Check what happens.
The affected port Te2/1/4 may be influenced by some near port configuration check the storm control settings on ports Te2/1/x this might explain what you see.
Your L2 switch is clearly a stack
can you post
show version
Hope to help
Giuseppe
09-15-2021 05:13 AM - edited 09-15-2021 05:14 AM
Thanks for your reply, i have some users who are log on this switch, i could only disable the storm-control configuration after 8 PM tonight.
See the show version below :
Switch Ports Model SW Version SW Image Mode
* 1 52 WS-C3650-48PD 03.06.03E cat3k_caa-universalk9 INSTALL
2 52 WS-C3650-48PD 03.06.03E cat3k_caa-universalk9 INSTALL
3 52 WS-C3650-48PD 03.06.03E cat3k_caa-universalk9 INSTALL
4 52 WS-C3650-48PD 03.06.03E cat3k_caa-universalk9 INSTALL
i haven't post all the reply, i think that you're looking for the IOS version from the stack, if you need something more specifically i will post it again
Kind regards, Dimitri.
09-22-2021 05:34 AM
Hello @Giuseppe Larosa,
I disable the storm control on the Port-channel, each Te port and on each cisco stack (L2 + L3).
I got the same problem :
Sep 22 13:35:50.605 PARIS: %EC-5-L3DONTBNDL2: Te2/0/3 suspended: LACP currently not enabled on the remote port.
Sep 22 13:36:32.585 PARIS: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/0/3, changed state to down
Sep 22 13:36:33.075 PARIS: %DTP-5-NONTRUNKPORTON: Port Te2/0/3 has become non-trunk
Sep 22 13:37:15.105 PARIS: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/0/3, changed state to up
Sep 22 13:37:15.596 PARIS: %DTP-5-TRUNKPORTON: Port Te2/0/3 has become dot1q trunk
Sep 22 13:37:22.886 PARIS: %EC-5-L3DONTBNDL2: Te2/0/3 suspended: LACP currently not enabled on the remote port.
I try to force the lacp on each Te with : channel-protocol lacp but i still have the problem...
