Intermittent Error in CE Router
demoschairos
Hi Guys,
Do you all know what is the primary cause when I see the Intermittent between O and O IA in CE routing Table.
2 Sites using OSPF Area 0.
This is the topology ;
Topologi
= CE HQ = <-> = PE HQ = <-> Cloud Telkom <-> = PE DRC = <-> = CE DRC =
Thx,
Suryanto
Giuseppe Larosa
Hello Suryanto,
you should provide more details about this, for example the time cycle of events:
is this happening regularly every N seconds and routes appear again after M seconds or it is a random pattern?.
is the topology so simple or there are multiple paths and other MPLS VPN sites?
Hope to help
Giuseppe
This is happening when I do the clear ip ospf process in DRC sites.
It is intermittently happened in the random pattern.
Between CE there is two link MPLS 1 and MPLS 2 .
