INTSTACK error
carringtonmc
I'm currently working with a Cisco 3800 as a part of my network. Over the passed couple of days, the router has locked up, the activity light staying a solid green, instead of blinking. When I attempted to console in, I received this error:
INTSTACK: Stack for level Network interfaces running low, 0/9000
If anyone could give me some clarification as to what this means, and also some reasons as to why a Cisco 3800 may be frequently locking up, I would greatly appreciate it. I'm currently in a learning process with Cisco routing. Thank you for your time.
paolo bevilacqua
Which exact IOS are you using ?
Cisco IOS Software, 3800 Software (C3845-ADVIPSERVICESK9-M), Version 12.4(12), RELEASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 12.3(11r)T1, RELEASE SOFTWARE (fc1)
Cisco 3845 (revision 1.0) with 1007616K/40960K bytes of memory.
Processor board ID FTX0918A1X1
You should upgrade to 12.4(3j) as first step. If the message remains, more investigation would be needed. Currently, the bug database is down to search on it.
