IOS 15 aaa Problem
Greeting I am configuring aaa privilege I found that more command is adding automatically. I can not remove this command and If I successfully remove it ; it remove main command also .
I configure the below command ;
privilege interface level 4 shutdown
privilege configure level 4 interface
privilege exec level 4 configure terminal
privilege exec level 4 show port-security
privilege exec level 4 clear port-security all
but when do sh run ; the below highlighted bold command will appear ;
this cause many problem in privilege Can any body help me ??!!!
6 Replies 6
Philip D'Ath
What model Cisco device is this, and what software version are you running on it?
Dear Philip;
the switch is 2960 and IOS version is 15.2
Could you give me the specific model number from "show inventory" please.
kindly check the switch model Catalyst 2960-24TC-L Switch
15.2 is not available for that model.  Are you running 15.0.2-SE9?  If not, try moving to that release.
all IOS Version 15 have the same issue . I had been installed all IOS related to Version 15 but the problem still exist
