IOS Command Defaults
chrisayres
Is there an easy way to find out whether commands are on or off by default in various versions of IOS
andrew.prince
Level 10
Level 10
Chris
I would suggest you read the specific command reference guide pertaining to the level of IOS and see what the defaults are.
HTH>
