IOS import AES keys
Hermozol
Hello Community.
I would like to establish Certificate-based SIP-trunk to WxC. When tried to import crypto key generated outside router
crypto key import rsa ownKEY general-purpose exportable terminal p@ssword
there is a problem. Only 3DES ecrypted password is accepted. No AES, no unencrypted only 3DES.
Other thing is that debug do not shows it in clear alert but some numbers like -1 or 11.
Next thing that key export allows to AES key encryption but You are not able to import it back.
So in 2024 it should be shame that Cisco accept only weak algorithm.
Tested on Virtual XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.9.4a
Hermozol
0 Replies 0
