IOS Install of 2811 - tftpdnld 32 MB limit?
inoc_noc
I'm attempting to install an IOS image (about 53 MB in size) on the flash of a 2811 router, however the transfer times out after 32 MB have been transferred. I've tried two different tftp server software packages with the same result. Does the tftpdnld have a 32 MB limit? I haven't seen this limit mentioned in any of the Cisco literature I've read.
If this limit exists, what would be the best method of getting the image on the flash? xmodem?
9 Replies 9
cisco24x7
Level 6
Level 6
Use Linux tftp built in and you will not have this issue. Sorry I am not familiar with Windows platform:
R2851-3#copy tftp: flash:
Address or name of remote host []? 10.109.114.10
Source filename []? c2800nm-advipservicesk9-mz.124-11.T4.bin
Destination filename [c2800nm-advipservicesk9-mz.124-11.T4.bin]?
Accessing tftp://10.109.114.10/c2800nm-advipservicesk9-mz.124-11.T4.bin...
Loading c2800nm-advipservicesk9-mz.124-11.T4.bin from 10.109.114.10 (via GigabitEthernet0/0): !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[OK - 41977164 bytes]
41977164 bytes copied in 172.848 secs (242856 bytes/sec)
R2851-3#dir flash:
Directory of flash:/
1 -rw- 38444260 Feb 20 2009 20:03:00 +00:00 c2800nm-advipservicesk9-mz.124-16.bin
2 -rw- 51133020 Feb 20 2009 20:09:02 +00:00 c2800nm-advipservicesk9-mz.124-15.T6.bin
3 -rw- 57637932 Mar 20 2009 21:43:40 +00:00 c2800nm-advipservicesk9-mz.124-24.T.bin
4 -rw- 4053 Mar 28 2009 16:18:04 +00:00 running.txt
5 -rw- 12699 Apr 17 2009 17:41:22 +00:00 http10.pdlm
6 -rw- 41977164 Jun 26 2009 14:59:52 +00:00 c2800nm-advipservicesk9-mz.124-11.T4.bin
256471040 bytes total (67252224 bytes free)
R2851-3#
Collin Clark
FTP is your best bet to transfer large files. Some TFTP applications are limited to 32MB, but there are also some w/o the limitation. Here's one-
http://tftpd32.jounin.net/tftpd32.html
Copying via FTP-
copy ftp flash:
Guys, thanks for the responses, but the crucial factor here is that I am using the tftpdnld command in ROMMON mode because I don't have an IOS on the flash, hence I don't have access to the 'copy' command.
You still need to use a Linux tftp version that will not have the 32MB limitation. That will be true regardless whether you use "copy" or "tftpdnld". here is a sample:
R2851-3#reload
Proceed with reload? [confirm]
System Bootstrap, Version 12.4(13r)T5, RELEASE SOFTWARE (fc1)
Copyright (c) 2007 by cisco Systems, Inc.
Initializing memory for ECC
c2851 platform with 524288 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Upgrade ROMMON initialized
PC = 0xbfcd0d54, Cause = 0x2000, Status Reg = 0x3040a803
rommon 1 >
rommon 5 > IP_ADDRESS=192.168.15.201
rommon 6 > IP_SUBNET_MASK=255.255.255.0
rommon 7 > DEFAULT_GATEWAY=192.168.15.1
rommon 8 > TFTP_SERVER=10.109.114.10
rommon 9 > TFTP_FILE=c2800nm-advipservicesk9-mz.124-24.T.bin
rommon 10 > tftpdnld
IP_ADDRESS: 192.168.15.201
IP_SUBNET_MASK: 255.255.255.0
DEFAULT_GATEWAY: 192.168.15.1
TFTP_SERVER: 10.109.114.10
TFTP_FILE: c2800nm-advipservicesk9-mz.124-24.T.bin
TFTP_VERBOSE: Progress
TFTP_RETRY_COUNT: 18
TFTP_TIMEOUT: 7200
TFTP_CHECKSUM: Yes
TFTP_MACADDR: 00:0a:b8:02:d4:c0
GE_PORT: Gigabit Ethernet 0
GE_SPEED_MODE: Auto
Invoke this command for disaster recovery only.
WARNING: all existing data in all partitions on flash: will be lost!
Do you wish to continue? y/n: [n]: y
Receiving c2800nm-advipservicesk9-mz.124-24.T.bin from 10.109.114.10 !!!!!!!!!!!
File reception completed.
Validating checksum.
Copying file c2800nm-advipservicesk9-mz.124-24.T.bin to flash:.
program load complete, entry point: 0x8000f000, size: 0xcb80
Format: All system sectors written. OK...
Format: Operation completed successfully.
Format of flash: complete
rommon 11 >
rommon 11 > boot
program load complete, entry point: 0x8000f000, size: 0x36f7a64
Self decompressing the image : ###################################################################################################################################################################################################################################################################################################################################### [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0003E9 0X00474800 C2851 Mainboard
0X00262B0A Onboard VPN
0X000021B8 Onboard USB
00014B 0X00016804 Virtual Private Network (VPN) Module
0X002C29F0 public buffer pools
0X00211000 public particle pools
TOTAL: 0X00BC36B6
Installed image archive
Cisco 2851 (revision 49.46) with 512000K/12288K bytes of memory.
Processor board ID FTX1032A20M
2 Gigabit Ethernet interfaces
1 Serial(sync/async) interface
2 Virtual Private Network (VPN) Modules
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
Press RETURN to get started!
User Access Verification
Username: cciesec
Password:
R2851-3>en
Password:
R2851-3#
Make sense right?
pompeychimes
Level 4
Level 4
Use a smaller image (<32MB) to start then upgrade to the larger image via FTP.
I had the same problem with a 2811 router in ROMMON mode and an IOS image of 58 MB of size in a Flash memory of 64 MB. I tried with several TFTP server software (tftpd32 among others), but it always get stuck and timed out at around 60% of the TFTP transfer, by using the tftpdnld ROMMON mode command
In order to make it work, I did the following:
1. Transfered an IOS image of 16 MB using the tftpdnld ROMMON mode command. This time the TFTP transfer ended successfuly
2. Issued the boot command from ROMMON mode. The router booted the IOS
3. Delete the IOS image of 16 MB with the delete flash: IOS command
4. Used the copy tftp flash: IOS command to TFTP transfer the IOS image of 58 MB
5. Configured the boot system flash: IOS command
6. Issued the copy run start IOS command
7. Issued the reboot IOS command. The router finally booted with the IOS image of 58 MB
Leo Laohoo
Have you read Colin Clark's response? Use TFTP32.
I've used TFTP32 with TFTPDNLD combination (several times) and I've yet to see a failure.
Yes TFTPD32 is the best bet...
