IOS Load Balancing question
s.debenito
Does anyone know how can I use more than one virtual server address? I mean something like a "secondary" option when configuring 2 IP addresses on typical interfaces.
I know there is an optional parameter called "group", but it is used for an entire subnet. The problem is that I have some servers on that subnet wich don't need to be balanced.
Thanks in advance.
mounir.mohamed
Level 7
Level 7
I think you can use extendable NAT entry to solved your server load-balance issues, also i had used IP-SLP on Cisco 6500 before and working great.
Please rate helpful posts.
Best Regards,
Mounir Mohamed
