Highlighted
Beginner
IOS required for PA-MCX-2TE1
I have 3 of these cards and would like to use them in my 7301's or 7206's
the Software Advisor doesn't like this card, it never returns anything...
anyone any advice ?
5 REPLIES 5
Highlighted
Hall of Fame Mentor
Re: IOS required for PA-MCX-2TE1
According to
http://www.cisco.com/en/US/products/hw/modules/ps2033/prod_bulletin09186a008007d45a.html
It should be fine as long as you have 12.1(5)T or later
HTH,
__
Edison.
Highlighted
Hall of Fame Master
Which 7200 are these? The card can be used only on VXR chassis.
Highlighted
Beginner
i only have vxr chassis with npe 300 or 400 or npe g1 processors, the only recomeded ios ref is for 12.2 xy or similar that is no longer available,
i would ideally like to run these in the 7301, cco says they are supported....
Highlighted
Beginner
i've tried the latest SP 12.4 that's no good (on the 7301)
Highlighted
Hall of Fame Master
CCO can be wrong on occasions. These cards had a limited production and some info can be wrong about it. Test it first in a 7200 chassis to verify it's working.
