IOS Selection Assistance
sfossett
I am trying to find an IOS release for a 2811 router that support an HWIC-1FE interface card, and also supports STUN commands. For some reason STUN isn't supported in the newer 12.4 IOS's that do support the HWIC. Is STUN no longer being supported at all, or did the commands just change? Any help would be much appreciated. THanks.
purohit_810
Level 5
Level 5
You can select specific future IOS on
www.cisco.com/go/fn
Dharmesh Purohit
purohit_810
Level 5
Level 5
12.4(16) 12.4(4)T3
ED Release 12.4(15)T1 12.4(11)XW2 12.4(11)XJ4 12.4(6)XT 12.4(6)XE2 12.4(4)XC6 12.4(2)XA2
12.3(14)T7 12.3(11)YZ1 12.3(11)XL1 12.3(8)ZA
http://tools.cisco.com/ITDIT/CFN/Dispatch
Dharmesh Purohit
