IOS suggession
Shiji Varughese
Hai,
My organisation is plannig to move to MPLS technology with dual homing for ther entire branches.currentlu they are connected their banches using convesional Lease lines with Cisco 3845 as core roter and 1841 as branch router.
The IOS nad hardware details of the current router is following
Router:1841
DRAM:256K
Flash:64MB
IOS file:c1841-advsecurityk9-mz.124-19b.bin
Router:3845
DRAM:512K
Flash:64MB
IOS filr:c3845-advsecurityk9-mz.buffer_leak_fix.bin
For our New setup(MPLS) we need to enable BGP 4, IPSEC and QOS
Pllease suggest a sutable and stable version IOS for our 1841 and 3845 router (No of branches will be in between 1000-2000)
Your help will be more helpfull
rgds
Retheesh.od
Haris P
Level 4
Level 4
Dear ,
I prefer to get Advanced enterprise IOS /Advanced IP services IOS . Please see the below link and  attached file
http://www.cisco.com/application/pdf/en/us/guest/products/ps5460/c1037/ccmigration_09186a00801ace76.pdf
Haeris P
meperuma
Is your existing network is running with IPSec And QOS? I guess you will be using ipv4 bgp. The reason is that BGP on the CE is a mature technology. So, may not be much issue.
For qos
Hi Riteesh,
I would recommend you to use the Cisco Feature Naviagator to find what you want.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Kishore
