IOS support
rohitk
Hi!
I've two 7206VXR and I'd like to install additional PA-2FE-TX on tht.
IOS for 1st router:--C7200-IK9S-M), Version 12.3(13).
IOS for 2nd router:--(C7200-IK9S-M), Version 12.2(8)T5.
Thanks for help in advance!
paolo bevilacqua
Why not taking this expansion as a chance to upgrade both router to something like latest 12.3 that should be very stable ?
It should work on both routers as it is, but if you also upgrade IOS will give you all the bug fixes amde in the meantime, and the router a fresh start with clean data structures.
Hope this helps, if so please rate post!
Hi!
Thank you,I've ios 12.3 as mentioned above and I'd upgrade, however one PA-2FE-TX already installed.I'd like to install addtional PA-2FE-TX , will those IOS support aadditional one.
Hi!
I am having Addintional PA-2FE-TX for MPLS circuit.Can u suggest me which IOS is compatible to use 2nos. PA-2FE-TX in 7206 VXR.
Hi Rohit
do check out software advisor tool which mite help you in finding out the exact ios code required in your box to support the modules.
Its also instrumental in giving the details about the memory and flash requirements to accommodate the ios.
http://tools.cisco.com/Support/Fusion/FusionHome.do
regds
