IOS upgrade required for Cisco ISR 4000 and Cisco Catalyst 9400.
ravi310859
We are planning to upgrade IOS for below mentioned devices. Kindly recommend the suitable and stable version with upgrade path. Kindly confirm if direct upgrade to target version is possible and how much downtime will be required to perform these task.
1) Cisco ISR 4000
Current version : Version 16.12.3
2) Cisco Catalyst 9400
Version 16.6.2r[FC1]
Thanks & Regards
Ravi.C
marce1000
 - ISR 4000 : https://software.cisco.com/download/home/286006221/type/282046477/release/Bengaluru-17.6.3a
  Catalyst 9400 : https://software.cisco.com/download/home/286316710/type/282046477/release/Bengaluru-17.6.4  , in both case read the Release Notes of the targeted version(s), you will then find info's concerning the upgrade path and you will be able to make an estimate of the involved downtime(s)
 M.
marce1000
 M.
