IOS Version
denaumcisco
Is there a IPBASE version that I can use ipv6?
As far as i know you need Advanced IP services for IPv6 on the 2800 series routers. The best place to check these sort of things is with Cisco's Feature Navigator -
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
I had a quick check for you and IP Base on the 2800 version 12.4T does not support IPv6.
Jon
Jon Marshall
Which device ?
It is a router 2800 family (2811 and 2821)
Jon
thanks Jon
