IOS-XE missing object-group network command?
campbech1
I'm in the process of installing four Cisco 4451-X routers and see that the object-group network command is missing?! There is an object-group security but no network.
Will this be coming back or am I missing something?
10 Replies 10
Steve Wood
Did you get any resolution to this problem as I have the same issue
Nothing at all. No one seems to have an answer. I'm going to call my Cisco SE later today.
Yep I am going to raise with our distributor
I am having the same problem with IOS asr1001-universalk9.03.09.01.S.153-2.S1.bin, but I could figure out on another ASR1001 that the command is available in this very old IOS-Version: asr1001-universalk9.03.06.00.S.152-2.S.bin
So anyway - can You confirm that the "object-group network" command ist available on Version 03.12.01.S ?
Stefan
Stefan,
This cmd is again availabe from ;
Release 4.3.1
To configure a network object group, and to enter the network object group configuration mode, use theobject-group network command in the global configuration mode. To de-configure the network object group, use the no form of this command.
object-group network { ipv4 | ipv6 object-group-name
no object-group network { ipv4 | ipv6 object-group-name
Syntax Description
ipv4
Configures the operation state of an IPV4 network object group.
ipv6
Configures the operation state of an IPV6 network object group.
object-group-name
Name of the object-group.
Command Default
None
Command Modes
Global configuration
Command History
ReleaseModification
Release 4.3.1
This command was introduced.
How to Solve a Problem?
Please help.
campbech1
I'm late to update this post but it looks like the command is back in Cisco IOS XE Software, Version 03.12.01.S - Standard Support Release.
object-group network SRS_Internal
 host 10.138.244.11
 host 10.138.244.12
Thank's  for your reply campbech1 !
But my version:
Cisco IOS XE Software, Version 03.10.02.S - Extended Support Release
Cisco IOS Software, ISR4400 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.3(3)S2, RELEASE SOFTWARE (fc3)
What's wrong???
campbech1
I don't believe it was supported until version 3.12 and you're on 3.10 currently. You'll need to complete a software upgrade.
Believe me.
<<You'll need to complete a software upgrade.>>
Ok, I will try.
