取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
ios-xe nat mode issue
ZeroCSC
I want to change the symmetrical nat of ios-xe pat to other modes.
Had refer to these two docs Understand NAT to Enable Peer-To-Peer Communication on IOS and IOS-XE Routers 以及IP Addressing: NAT Configuration Guide  and changed the nat type to CGNAT, the test still doesn't work, does anyone know how to enable EIM in CGN mode? Thank you so much.
I tested again after a while, it became FullCone. . .
1 条回复1
you enabled CGNAT ('ip nat settings mode cgn') ? What result are you looking for ?
