%IOSXE_INFRA-5-PUNT_SVC_INVALID_OPT_PKT: Invalid IPv4 options packet punted to RP
vinit shah
                   HI team,
Kindly assist for the mentioned error.....
Need to find the reason behind the said log and need a recommended action to overcome the log.
Kindly confirm about the service impact because of the said logs or not.
" %IOSXE_INFRA-5-PUNT_SVC_INVALID_OPT_PKT: Invalid IPv4 options packet punted to RP"
fyi.....
------------------ show version ------------------
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 15.3(2)S1a, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Fri 31-May-13 14:34 by mcpre
IOS XE Version: 03.09.01a.S
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
MP-RPR-PS-ASR1 uptime is 2 weeks, 10 hours, 5 minutes
Uptime for this control processor is 2 weeks, 10 hours, 8 minutes
System returned to ROM by reload at 00:51:47 IST Fri Jul 19 2013
System restarted at 01:33:21 IST Fri Jul 19 2013
System image file is "bootflash:asr903rsp1-universalk9_npe.03.09.01a.S.153-2.S1a.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: metroaggrservices
License Type: Permanent
Next reload license Level: metroaggrservices
cisco ASR-903 (RSP1) processor with 437416K/6147K bytes of memory.
Processor board ID FOX1638P25X
16 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
2097152K bytes of physical memory.
1328927K bytes of SD flash at bootflash:.
Vinit
CSCO12241031
Are there any suggestions as to what this message means?
Having done a packet capture on the control-plane in this is the only packet which stands out:
UDP 1450 Source port: 20591  Destination port: 64621 [BAD UDP LENGTH 36553 > IP PAYLOAD LENGTH]
