cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
Respostas
IP Accounting 3560E
snarayanaraju
Level 4
Level 4
Hello Guys - I am using a 3560E switch with IOS version 12-2_55_se (Universalk9). Though i am seeing the command "ip accounting" under IP interfaces, "show ip accounting" doesnt show any entries. Also the command reference guide doesnt show the guide for this command
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750e_3560e/software/release/12-2_55_se/command/reference/3750ecr.pdf
Does IP accounting or IP route cache work in 3560E platform? How can i find the toptalkers or high bandwidh user if my WAN gateway device is Cisco 3560-E
regards/Sairam
1 Soluções Aceita
Soluções aceites
IP Accounting is apparently not supported on the 3560E.
Check this document, and scroll down to 'Unsupported Interface Commands':
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750e_3560e/software/release/12-2_55_se/configuration/guide/3750escg/swuncli.html
Unsupported Interface Configuration Commands
ip accounting
ip load-sharing [per-packet]
ip mtu bytes
ip ospf dead-interval minimal hello-multiplier multiplier
ip verify
ip unnumbered type number
Ver solução na publicação original
4 RESPOSTAS 4
ip accounting
ip mtu bytes
ip verify
Thank you. But i am wondering why the platform still has the command allows to me to configure
RTR01(config-if)#ip accounting ?
access-violations Account for IP packets violating access lists on this interface
mac-address Account for MAC addresses seen on this interface
output-packets Account for IP packets output on this interface
precedence Count packets by IP precedence on this interface
RTR01#show ver | in System image
System image file is "flash:/c3750e-universalk9-mz.150-1.SE3/c3750e-universalk9-mz.150-1.SE3.bin"
it happens quite frequently that commands are available but don't work, or are unsupported. The reason is usually hardware limitations.
Thank you. If that said, what is the way i can capture the Top Talkers or to know who is using the bandwidth heavily ?
