IP address finding
rotoorangi
How do I find out the IP address of a aironet 1131ag wireless router?
If it plugged into Cisco switch or router you may see for CDP neighbour on that interface. If CDP is enabled on both devices, of course.
If switch is not cisco and CDP still enabled on AP, you can still sniff CDP broadcast from AP, using tcpdump or WireShark.
just for start. there is also many other options depending on your architecture.
