IP address pools
Konstantin_Sh
Hello!
I am not sure that my question is in the right topic, please correct if not.
So, I really need help of Cisco GGSN experts:
In the GGSN R7.0 there is the feature "hold back timer" which I can administer via the parameter "recycle delay" in the command "ip local pool".
The similar behaviour is realized in previuos releases but I do not know how to administer such timer and also to check how much this timer is.
From other people I've heard that it is possible to adjust this timer via parameter "cache-size" in the same command "ip local pool" in e.g. GGSN R6.0.
Is it true? What is the correct meaning of parameter "cache-size" and its values?
Thank you in advance for your help.
Konstantin
vkapoor5
Level 5
Level 5
I don't think we can adjust the time using the parameter cache-size.
Hello!
But do you know how to check what is its
current value?
BR
Konstantin
