05-22-2013 10:44 AM - edited 03-04-2019 07:58 PM
Does ip default-gateway have any effect on a L3 device such as a 2811 router? I always thought that on a L3 device the default route would supersede any such command assuming it is accepted.
We have a client device that cannot be reached for managment directly and wanted to add that statment only if it might help.
Thanks.
Solved! Go to Solution.
05-22-2013 10:48 AM
"ip default-gateway" is only relevant if "ip routing" is disabled.
05-22-2013 10:48 AM
