ip default-network problem
iamtheone12345
Hi Guys,
I am having some issues with ip default-network command on packet tracer.
I have a toplogy of few routers running rip version 2.
I have configured ip default network command on one router pointing to to candiddate networks (2 sepearte static routes with 2 separate ip default-network
command.)The command seems to work properly as i can reach an outside network via one candidate network only at one time(the one that is first in the routing table).
However ,the RIP-2 is not propogating the ip default-network static routes to other routers.Am i doing something wrong here ?Should i be using RIP rather than RIP-2 ? i have pointed classfull networks in the ip default-network command.
If any one wants to look at the PT file i can certainly attach it.
Arjun Das
Richard Burts
Arjun Das
We need more detail about the topology and the configuration that you have done before we can identify the real problem and suggest solution. I do not have anything that can read packet tracer files. So perhaps you can just post the information? At a minimum we would want to see the specific default-network commands and the output of show ip route. Any other details you can provide might be helpful.
Rick
Rick
Hi Richard,
All the details are below:(the topology is attached )
CBTRouter config
CBTrouter#show run
Building configuration...
hostname CBTrouter
interface FastEthernet0/0
description ###INTERNET ROUTER CONNCETION###
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial1/0
ip address 68.110.171.98 255.255.255.224
no cdp enable
clock rate 64000
interface Serial1/1
ip address 100.110.171.98 255.255.255.0
clock rate 64000
interface Serial1/2
no ip address
interface Serial1/3
no ip address
router rip
network 68.0.0.0
network 100.0.0.0
network 192.168.1.0
ip classless
ip default-network 4.0.0.0
ip default-network 5.0.0.0
end
CBTrouter#show ip route
Gateway of last resort is 68.110.171.97 to network 4.0.0.0
R*   4.0.0.0/8 [120/1] via 68.110.171.97, 00:00:16, Serial1/0
R*   5.0.0.0/8 [120/1] via 100.110.171.97, 00:00:21, Serial1/1
     68.0.0.0/27 is subnetted, 1 subnets
C       68.110.171.96 is directly connected, Serial1/0
     100.0.0.0/24 is subnetted, 1 subnets
C       100.110.171.0 is directly connected, Serial1/1
C    192.168.1.0/24 is directly connected, FastEthernet0/0
R    192.168.2.0/24 [120/1] via 192.168.1.2, 00:00:24, FastEthernet0/0
R    192.168.3.0/24 [120/2] via 192.168.1.2, 00:00:24, FastEthernet0/0
R1 config
R1#show run
hostname R1
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Serial1/0
ip address 192.168.2.1 255.255.255.0
clock rate 64000
interface Serial1/1
no ip address
interface Serial1/2
no ip address
interface Serial1/3
no ip address
interface Vlan1
no ip address
shutdown
router rip
network 192.168.1.0
network 192.168.2.0
ip classless
end
R1#show ip route
Gateway of last resort is not set
R    4.0.0.0/8 [120/2] via 192.168.1.1, 00:00:18, FastEthernet0/0
R    5.0.0.0/8 [120/2] via 192.168.1.1, 00:00:18, FastEthernet0/0
R    68.0.0.0/8 [120/1] via 192.168.1.1, 00:00:18, FastEthernet0/0
R    100.0.0.0/8 [120/1] via 192.168.1.1, 00:00:18, FastEthernet0/0
C    192.168.2.0/24 is directly connected, Serial1/0
R    192.168.3.0/24 [120/1] via 192.168.2.2, 00:00:13, Serial1/0
R2 config
R2#show run
hostname R2
ip address 192.168.3.1 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Serial1/0
ip address 192.168.2.2 255.255.255.0
interface Serial1/1
no ip address
interface Serial1/2
no ip address
interface Serial1/3
no ip address
interface Vlan1
no ip address
shutdown
router rip
network 192.168.2.0
network 192.168.3.0
ip classless
end
R2#show ip route
R    4.0.0.0/8 [120/3] via 192.168.2.1, 00:00:23, Serial1/0
R    5.0.0.0/8 [120/3] via 192.168.2.1, 00:00:23, Serial1/0
R    68.0.0.0/8 [120/2] via 192.168.2.1, 00:00:23, Serial1/0
R    100.0.0.0/8 [120/2] via 192.168.2.1, 00:00:23, Serial1/0
R    192.168.1.0/24 [120/1] via 192.168.2.1, 00:00:23, Serial1/0
C    192.168.3.0/24 is directly connected, FastEthernet0/0
ISPRouter config
ISProuter#show run
hostname ISProuter
interface Loopback1
ip address 4.2.2.1 255.255.255.0
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
interface Serial1/0
ip address 68.110.171.97 255.255.255.224
interface Serial1/1
no ip address
interface Serial1/2
no ip address
interface Serial1/3
no ip address
interface Vlan1
no ip address
shutdown
router rip
network 4.0.0.0
network 68.0.0.0
ip classless
end
ISProuter#show ip route
     4.0.0.0/24 is subnetted, 1 subnets
C       4.2.2.0 is directly connected, Loopback1
R    5.0.0.0/8 [120/2] via 68.110.171.98, 00:00:20, Serial1/0
R    100.0.0.0/8 [120/1] via 68.110.171.98, 00:00:20, Serial1/0
R    192.168.1.0/24 [120/1] via 68.110.171.98, 00:00:20, Serial1/0
R    192.168.2.0/24 [120/2] via 68.110.171.98, 00:00:20, Serial1/0
R    192.168.3.0/24 [120/3] via 68.110.171.98, 00:00:20, Serial1/0
ISPRouter2 config
ISPRouter2#show run
hostname ISPRouter2
interface Loopback1
ip address 5.2.2.1 255.255.255.0
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
interface Serial1/0
ip address 100.110.171.97 255.255.255.0
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface Vlan1
no ip address
shutdown
router rip
network 5.0.0.0
network 100.0.0.0
ip classless
end
ISPRouter2#show ip route
R    4.0.0.0/8 [120/2] via 100.110.171.98, 00:00:25, Serial1/0
     5.0.0.0/24 is subnetted, 1 subnets
C       5.2.2.0 is directly connected, Loopback1
R    68.0.0.0/8 [120/1] via 100.110.171.98, 00:00:25, Serial1/0
C       100.110.171.0 is directly connected, Serial1/0
R    192.168.1.0/24 [120/1] via 100.110.171.98, 00:00:25, Serial1/0
R    192.168.2.0/24 [120/2] via 100.110.171.98, 00:00:25, Serial1/0
R    192.168.3.0/24 [120/3] via 100.110.171.98, 00:00:25, Serial1/0
Hi richard,
By the way i am now running RIP-1 in this lab.No static routes configured.I am using RIP in all routers.
used ip default-network on CBTrouter to point to 2 networks as candidate for default route.
