IP fast switching on the same interface
Hi all,
a question about the entries highlighted in show ip interface <>
R1#sh ip int s0/0
Serial0/0 is up, line protocol is up
  Internet address is 10.0.0.1/30
  Broadcast address is 255.255.255.255
  Address determined by non-volatile memory
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Multicast reserved groups joined: 224.0.0.5
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
IP fast switching is enabled  <----------------------------------------------------------------------------
  IP fast switching on the same interface is enabled  <-------------------------------------------
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF Fast switching turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is disabled
  BGP Policy Mapping is disabled
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
What is the difference between them ?
Thanks, Carlo.
Richard Burts
Carlo
These two things are related to the way that Cisco did forwarding of IP traffic before they developed CEF. Before CEF most of the forwarding on IOS routers used process switching and fast switching. Process switching was the default method and fast switching was an enhancement to make packet forwarding more efficient. Fast switching built a cache based on traffic that it had processed. The fast switching cache was demand driven, which means that the router built the cache entries as it saw traffic coming through the router to be forwarded. By default the router would build the cache only for traffic that entered on one interface and exited on another interface. So by default traffic that entered on one interface and was forwarded out the same interface did not build a cache entry. There was a special config option to tell the router to also build cache entries when traffic was forwarded out the same interface. And this is what the second output is about - will the router build fast switching cache for packets switched back out the same interface. In this case that option is on.
Now that CEF is used on IOS routers Fast Switching and Fast Switching Same Interface are really not used. But they still show up in the show command output for backward compatibility with older IOS.
Rick
Rick
Hi Richard,
Two years too late !!! but I have a question on this. Does CEF by default support same interface switching in Hardware ?
Thanks in Advance
Umesh
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Generally the small routers do everything in software, including CEF.  L3 switches, and some high end routers, support forwarding with special hardware.
Umesh
I would agree with Joseph that if CEF is implemented in hardware then a packet forwarded out the same interface that it arrived on will still be forwarded using CEF in hardware.
I would then go a step further with this observation. For Fast Switching, in which the cache is demand driven, Cisco implemented an efficiency in which by default it did not build a cache entry if the packet is forwarded out the interface on which it arrived. They then created an option that if you wanted that functionality that you could enable it. The implementation of CEF is different. The cache is not demand driven but is calculated before packet forwarding begins. The cache includes a forwarding table and an adjacency table (where the layer 2 rewrite information is stored). The adjacency table includes every adjacency, no matter which interface. So there is no concept or no dependency in CEF on same interface.
Rick
Rick
