I have a static NAT configuration that works perfectly, save for one entry. Whenever I try to use the static nat entry for udp port 61234, the "wanted port" of 61234 is never equal to the "got" port. I assume this means the translation failed.
Can anyone help me understand what's going on, and how to correct it? I can't use any applications on this port, even after a reload of the router (or after executing a clear ip nat trans * or clear ip nat trans force).
Configuration
interface FastEthernet0/0
ip address 192.168.200.1 255.255.255.0
ip nat inside
no ip route-cache cef
no ip route-cache
no ip mroute-cache
load-interval 30
speed 100
full-duplex
hold-queue 600 in
interface Ethernet1/0
ip address dhcp client-id Ethernet1/0
ip nat outside
no ip route-cache
no ip mroute-cache
load-interval 30
half-duplex
hold-queue 600 in
ip nat inside source list 1 interface Ethernet1/0 overload
ip nat inside source static udp 192.168.200.11 61234 interface Ethernet1/0 61234
access-list 1 permit 192.168.200.0 0.0.0.255
Router#sh ip nat trans
Pro Inside global Inside local Outside local Outside global
udp 198.133.219.25:61234 192.168.200.11:61234 --- ---
When I debug ip nat detailed, I receive the following output:
.Feb 15 02:28:42.895: NAT: s=192.168.200.11->198.133.219.25, d=62.75.222.133 [28545]
.Feb 15 02:28:43.067: NAT: [0] Allocated Port for 192.168.200.11 -> 198.133.219.25: wanted 61234 got 1041
.Feb 15 02:28:43.067: NAT: o: udp (62.75.222.133, 38717) -> (198.133.219.25, 61234) [44622]
.Feb 15 02:28:43.071: NAT: s=62.75.222.133, d=198.133.219.25->192.168.200.11 [44622]
.Feb 15 02:28:43.071: NAT: i: udp (192.168.200.11, 61234) -> (62.75.222.133, 38717) [28547]
.Feb 15 02:28:43.071: NAT: UDP s=61234->1041, d=38717
.Feb 15 02:28:43.071: NAT: s=192.168.200.11->198.133.219.25, d=62.75.222.133 [28547]
.Feb 15 02:28:43.223: NAT: o: icmp (62.75.222.133, 38717) -> (198.133.219.25, 1041) [56801]
.Feb 15 02:28:43.227: NAT: s=62.75.222.133, d=198.133.219.25->192.168.200.11 [56801]
Router#sh ver
IOS (tm) C2600 Software (C2600-IK9O3S3-M), Version 12.3(20), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Tue 08-Aug-06 20:50 by kesnyder
Image text-base: 0x80008098, data-base: 0x81A0E7A8
