ip nat ... extendable
Kevin Dorrell
Level 10
Level 10
Can someone explain to me (or point me to a reference) what the extendable option does in an ip nat command? For example:
<b>
ip nat inside source static tcp local-ip port global-ip port extendable
</b>
The doumentation says:
extendable : "(Optional) Extends the translation"
which is about a much use for understanding as a bicycle is to a fish.
Kevin Dorrell
Luxembourg
Danilo Dy
Hi Kevin,
I think this links can explain more http://www.cisco.com/en/US/tech/tk648/tk361/technologies_white_paper09186a0080091cb9.shtml
..and Example 4-29 http://www.ciscopress.com/articles/article.asp?p=25273&seqNum=4
I use this in one implementation with the following ambiguous translations;
ip nat inside source static tcp 10.168.88.2 7002 192.168.88.2 443 extendable
ip nat inside source static tcp 10.168.88.2 1415 192.168.88.22 1414 extendable
Dandy
Danilo Dy
Hi Kevin,
Dandy
Thank you Dandy, those links explain it perfectly. I shall read that chapter of Doyle because it looks useful.
Kevin Dorrell
Luxembourg
