02-15-2008 01:21 PM - edited 03-03-2019 08:44 PM
I am using a cisco 1841 router and after I did an static translation on my router the lan users can no longer access the server. See below:
ip nat inside source static tcp 10.1.4.15 80 12.xxx.xxx.xxx 80 extendable
ip nat inside source static tcp 10.1.4.15 443 12.xxx.xxx.xxx 443 extendable
I am able to ping the WAN and LAN addresses used in the static map but the local users can't access the site. Any suggestions?
02-17-2008 04:33 AM
Your commands are absolutely fine and it should work well. Just want to ask one question had entered the
ip nat inside
ip nat outside
comamnds
regards
shivlu
02-17-2008 11:37 AM
Local users has nothing to do with your nat mappings.
Thoses mappings are required for external access purposes.
Your Lan users should be able to access the site if they within the Lan subnet. Other than that , check if you have any filtering done could eleminate Lan users from accessig a direct web-server.
Mohamed
