ip nat inside source static not working
rcordeiro
Hi all,
I have a 2951 configured with subinterfaces (for the inside networks) and NAT.
Outside NAT is working just fine but inside NAT is not working and I have no clue...
configs:
interface GigabitEthernet0/0
 ip address xxx.xxx.xxx.xxx 255.255.255.252
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/1.10
 encapsulation dot1Q 10
 ip address 192.168.10.254 255.255.255.0
 ip helper-address 192.168.10.10
 ip nat inside
interface GigabitEthernet0/1.20
 encapsulation dot1Q 20
 ip address 192.168.20.254 255.255.255.0
 ip nat inside
interface GigabitEthernet0/1.30
 encapsulation dot1Q 30
 ip address 192.168.30.254 255.255.255.0
 ip access-group 101 in
 ip nat inside
ip nat inside source static tcp 192.168.10.10 3389 interface GigabitEthernet0/0 3389
ip nat inside source route-map NAT interface GigabitEthernet0/0 overload
I'm not able to get a connection from outside to inside:
#sh ip nat trans
Pro Inside global         Inside local          Outside local         Outside global
tcp xxx.xxx.xxx.xxx:3389    192.168.10.10:3389    yyy.yyy.yyy.yyy:45378    yyy.yyy.yyy.yyy:45378
tcp xxx.xxx.xxx.xxx:3389    192.168.10.10:3389    ---                   ---
#sh ip nat stat
Total active translations: 426 (0 static, 426 dynamic; 426 extended)
Peak translations: 1144, occurred 02:05:28 ago
Outside interfaces:
  GigabitEthernet0/0
Inside interfaces:
  GigabitEthernet0/1.10, GigabitEthernet0/1.20, GigabitEthernet0/1.30
Hits: 1888451  Misses: 0
CEF Translated packets: 1849109, CEF Punted packets: 39341
Expired translations: 31243
Dynamic mappings:
-- Inside Source
[Id: 2] route-map NAT interface GigabitEthernet0/0 refcount 424
Total doors: 0
Appl doors: 0
Normal doors: 0
Queued Packets: 0
Nothing appears at the static translations.
Router is running 15.4.2.T but I also tried with several 15.2 releases and always the same behaviour.
16 Replies 16
rcordeiro
Hi have asked the guys at the location to check everything, let's see what they tell me...
Anyway, thanks for all of you who helped or tried to help.
Hi i was in similar situation. what we have found that the following command should be on the inside and outside interface
ip nat enable
 this will resolve the issue for Dynamic or Static NAT. plus use the following command to check stats
DXB-EDGE-C2911-03#show ip nat nvi translations
Pro Source global Source local Destin local Destin global
--- 185.100.209.176 10.124.32.253 --- ---
icmp 185.100.209.176:1474 169.47.140.23:1474 185.100.209.176:1474 10.124.32.253:1474
udp 185.100.208.2:123 185.100.208.2:123 185.100.209.176:123 10.124.32.253:123
udp 185.100.209.177:49152 185.100.209.177:49152 185.100.209.176:3784 10.124.32.253:3784
