ip nat inside
gio.bitsadze
ip nat inside source static tcp 192.168.200.45 5000 interface GigabitEthernet0/0/0 5000
%Port 5000 is being used by system
any guesses?
17 Replies 17
check if your IOS supports the command below:
ip nat settings interface-overload block port tcp 5000
Can anyone with a 16.6 XE or higher version test if the command:
frees that port for static NAT ?
That command don't works with 154 ((
It's interesting about 16.6 XE
