ip nat outside configuration
olly ahmed
Suppose I have an internet facing router in which NAT is active and have a partner connected via internet. Partner has a server on a real IP. I want to configure static NAT so that inside local addresses can access that server. Can anyone share a sample configuration for this configuration but only using the command "ip nat outside source static". No "ip nat inside source" should be configured. If you need any further clarification then feel free to ask.
trfinkenstadt
Since you already have NAT active and your partner is using a public IP (presumption on real IP), shouldn't your internal hosts already be able to access your partner via the NAT?
I might be missing something here.
