ip nat source static versus ip nat source static network
orbis
using NAT with NVI, the following statement:
ip nat source static 192.168.255.2 10.0.2.2 vrf kk-C1 extendable
enables communication with the internal host 192.168.255.2 using external
IP address 10.0.2.2. The destination address 10.0.2.2 gets translated to
192.168.255.2. In the opposite direction, the traffic from 192.168.255.2
coming out to the external network is subject to translation of the source
address 192.168.255.2 to 10.0.2.2. What is important, this works in both
directions without any problem.
The following statement:
ip nat source static network 192.168.255.2 10.0.2.2 /32 vrf kk-C1 extendable
does the same thing, because it translates to the same statement as the
previous one.
However, the following statement:
ip nat source static network 192.168.255.2 10.0.2.2 /31 vrf kk-C1 extendable
as well as the following one:
ip nat source static network 192.168.255.0 10.0.2.0 /24 vrf kk-C1 extendable
behave differently.
The traffic from 192.168.255.2 coming out to the external network is OK (NAT
works in exactly the same manner as described previously). However, the
traffic coming from external network to 10.0.2.2 won't get through UNTIL
at least one packet comes in the opposite direction...
Is this a bug or feature?
I would not call this a cool feature...
I would very appreciate any suggestions on how to configure this kind of NAT
for a bunch of internal hosts (actually, hundreds of them) without the need to
configure hundreds of ip nat statements (one for every pair of IP addresses).
Any ideas?
Rosta
Rosta,
You can configure nat pool, like the one noted below, to assign a global address from that pool for all your inside users. But, you would have no control over what global address the inside users get. If you are trying to access an inside user from outside then you can combine the one-to-one static NAT and the NAT pool for this work. If you combine them the exclude the one-to-one NATted address from the NAT pool address range.
ip nat inside source list 10 pool TEST vrf kk-C1
ip nat pool TEST 10.0.2.1 10.0.2.254 prefix-length 24
access-list 10 permit 192.168.255.0
Sundar
Sundar,
thanks for the advice. In fact, I need the NAT for management purposes
(I need to manage devices in possibly overlapping user networks, so the
first step is to "normalize" all the addresses to a common private
address range). So, I need to have the control over what global address
the inside devices get.
I really don't want to use hundreds of one-to-one static NAT entries.
Perhaps the "NAT Routemaps Outside-to-Inside Support" feature could be the
solution:
http://tinyurl.com/yxru9t
However I didn't find a way how to configure reversible NAT together with
VRF.
Anyway, thanks for your prompt reply.
Rosta
