IP Route-cache
Liam Dwyer
I am trying to configure netflows.  If adding the command ip route-cache to the interface that is configured with BGP routing will that cause problems/disruptions?
Also, the command should be ip route-cache flow as far as I know but the CLI will only accept ip route-cache.
thanks
Richard Burts
I believe that you are a bit confused about the relationship of flow switching and of NetFlow. The command ip route-cache flow is to enable flow switching. And it is easy be be confused because the command to display NetFlow results looks very much like Flow Switching - show ip route-cache flow. But the interface command that you use to enable NetFlow probably looks like this - ip flow egress (might depend on your plarform and version of code).
Rick
Rick
