IP routing scenario
thomuff
Level 3
Level 3
I have location A and location B
Location A connects to Location B primaryily through a T1 connection.
Secondary is a Frame Relay connection.
Is there a way to route a specific server at Location A to three specific servers at Location B and route those three back to the server at Location A over the Frame Relay Connection and what is the risks
Server A sits in a Location A one subnet
Servers B1,B2,B3 sit is Location B's one subnet.
8 Replies 8
pkhatri
Level 11
Level 11
Yes, you can achieve this using policy-based routing. There is no real risk with doing so - if the frame relay link goes down, the traffic will start going back over the T1 link.
Here's a sample config that you can use to achieve this:
Location A:
int fast0/0
ip address x.x.x.x y.y.y.y
ip policy route-map ToFR
int s1/0:1
description T1 link
int s2/0:1.16
description FR link
access-list 101 permit ip host host
route-map ToFR permit 10
match ip address 101
set interface s2/0:1.16
Location B:
int fast0/0
int s1/0:1
description T1 link
int s2/0:1.16
description FR link
Hope that helps - pls rate the post if it does.
Paresh
Thank you for replying
How would you do if the two connections are on seperate routers?
Thanks again
Tom
I don't know your topology but let's assume your server is forwards packets to a default gateway. The gateway router has the connections to your internet routers. In this scenario, PBR can be applied to the gateway router. The next hop address will be the internet router with the Frame Relay connection.
If you can please describe your topology I think that'd help.
Location A router 1 connects to Location router B router 1 via T1
Location A router 2 connects to Location router B router2 via Frame
Location A Lan subnet is 192.168.2.0 /24 GW is 192.168.2.1
Location B Lan subnet is 192.168.3.0 /24 GW is 192.168.3.1
Location A server 1 is 192.168.2.100
Location B server 1 is 192.168.3.100
Location B server 2 is 192.168.3.101
Location B server 3 is 192.168.3.102
Hope this helps
Tom
Location A router 2 ethernet is 192.168.2.2
Location B router 2 ethernet is 192.168.3.2
Thanks again
Tom
Are Location A and B router 1 the gateway 192.168.2.1 and 192.168.3.1 respectively? And if I understand you correctly router 1 and router 2 (at both sites) have IP connectivity via the LAN segment? Is router 2 connected directly to router 1 or is there a layer 2 device connecting both routers and the LAN segment?
If 192.168.2.1 and 192.168.3.1 are router 1 at location A and B apply PBR there. Configure your next hop ip as 192.168.2.2 for 2.1’ policy and 192.168.3.2 for 3.1’s policy.
Test first if you can.
Ryan
You are understand me. Router 1 an Router two connect via a Catalyst 4500 at both locations.
Thank you!
Here's a config that will achieve what you want:
Location A:
Router 1:
int fast0/0
ip address 192.168.2.1 255.255.255.0
int s1/0:1
description T1 link
access-list 101 permit ip host 192.168.2.100 host 192.168.3.100
access-list 101 permit ip host 192.168.2.100 host 192.168.3.101
access-list 101 permit ip host 192.168.2.100 host 192.168.3.102
set ip next-hop 192.168.2.2
ip route 192.168.3.0 255.255.255.0 s1/0:1
Router 2:
Location B:
Router 1:
int fast0/0
ip address 192.168.3.1 255.255.255.0
int s1/0:1
description T1 link
access-list 101 permit ip host 192.168.3.100 host 192.168.2.100
access-list 101 permit ip host 192.168.3.101 host 192.168.2.100
access-list 101 permit ip host 192.168.3.102 host 192.168.2.100
set ip next-hop 192.168.3.2
ip route 192.168.2.0 255.255.255.0 s1/0:1
Router 2:
Paresh
