ip sla feature
wajid dabir
c1900-universalk9-mz.SPA.152-4.M2.bin....my this image is supporting a ip sla feature.
But c1900-universalk9-mz.SPA.152-4.M1.bin image is not supporting the ip sla feature.
is i need to upgrade the image or i need any license to install in router?
Wajid,
As expected, you don't have Data k9 license installed.
Device#   PID                   SN
*0        CISCO1921/K9          FGL164723XU
Technology Package License Information for Module:'c1900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
data          None          None           None
data          None          None           None
You can compare this output with the release in which you are able to get IP SLA configuration. Refer to this document for more information regarding licenses and how you can enable on the router:
http://www.cisco.com/en/US/prod/collateral/routers/ps10616/white_paper_c11_556985_ps10537_Products_White_Paper.html
Subeh
Subeh Sharma
Hi Wajid,
IP SLA on ISR G2 platforms like your 1900 require Data K9 licence. Can you paste the output of show version with the non-working IOS image here?
Subeh
IMCL-PUN01-RTR008#show ver
IMCL-PUN01-RTR008#show version
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.2(4)M1, REL
EASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 26-Jul-12 19:34 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
IMCL-PUN01-RTR008 uptime is 3 weeks, 5 days, 23 hours, 42 minutes
System image file is "usbflash0:c1900-universalk9-mz.SPA.152-4.M1.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID FGL164723XU
2 FastEthernet interfaces
2 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
249840K bytes of USB Flash usbflash0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
data          None          None           None
data          None          None           None
Wajid,
Device#   PID                   SN
data          None          None           None
data          None          None           None
Subeh
