Join Customer Connection to register!
1924
IP SLA IS NOT WORKING IN c2600-ik9s-mz.122-46a.bin.
Dear Team,
We have Cisco2621XM router,  where in the below IP SLA is not supporting. Refering the Cisco feature navigator, understood that the below features will support c2600-ik9s-mz.122-46a.bin. But i am not able to execute IP SLA command in config mode.
The below are the features captured from Cisco feature navigator and the same are not supporting in c2600-ik9s-mz.122-46a.bin IOS.
IP SLAs - DHCP Operation
IP SLAs - Distribution of Statistics
IP SLAs - DLSW+ Operation
IP SLAs - DNS Operation
IP SLAs - FTP Operation
IP SLAs - History Statistics
IP SLAs - HTTP Operation
IP SLAs - ICMP Echo Operation
IP SLAs - ICMP Path Echo Operation
IP SLAs - One Way Measurement
IP SLAs - Reaction Threshold
IP SLAs - Scheduler
IP SLAs - SNA LU2 Echo
IP SLAs - SNMP Support
IP SLAs - TCP Connect Operation
IP SLAs - UDP Echo Operation
IP SLAs - UDP Jitter Operation
1 ACCEPTED SOLUTION
I've chosen the same features for IP SLA with Features Navigator and the lowest IOS version that support what you need it's 12.3, Enterprise features set.
See attachement.
I have here a 2600 with c2600-i-mz.123-1.bin, and:
(config)#rtr ?
  <1-2147483647>          Entry Number
  key-chain               Use MD5 authentication for RTR control message
  low-memory              Configure low water memory mark
  reaction-configuration  RTR Reaction Configuration
  reaction-trigger        RTR trigger assignment
  reset                   RTR Reset
  responder               Enable RTR Responder
  restart                 Restart an active entry
  schedule                RTR Entry Scheduling
  slm                     Service Level Management
I think you have to upgrade.
Calin
4 REPLIES 4
Calin C.
Contributor
Does it work with rtr command instead of ip sla ?
Cheers,
Calin
Hi Calin,
No, None of the commands are working. I have attatched the o/p.
Sigeesh
See attachement.
(config)#rtr ?
  reset                   RTR Reset
Calin
Hi Calin ,
The configuration is fine after IOS upgrade. Thanks for your inputs.
