08-27-2013 12:38 AM - edited 03-04-2019 08:52 PM
Hi All
We have a router that is connected to 2 firewalls, these 2 firewall have access to the internet via 2 different service providers, from time to time one of these links go down, which triggers a manaul proccess of routing specific destination over the other link. The solution i ha va come up with is as follows:
The IP Sla below will check if it can send and recieve an icmp request to a destination
ip sla monitor 1
type echo protocol ipIcmpEcho 196.xxx.xxx.xxx source-ipaddr xxx.xxx.xxx.xxx
timeout 3000
frequency 30
hours-of-statistics-kept 1
ip sla monitor reaction-configuration 1 react timeout threshold-type immediate action-type trapOnly
ip sla monitor schedule 1 life forever start-time now
I then track this ip sla
track 1 rtr 1 reachability
If the icmp does not reply follow a less reliable route until the primary route comes back up then it will follow the more reliable route
ip route 196.xxx.xxx.xxxx 255.255.255.255 10.xxx.xxx.xxx 5 name RouteCellSysFtp(backuproute)
More reliable route
ip route 196.xxx.xxx.xxx 255.255.255.255 10.xxx.xxx.xx name RouteCellSysFtp(primaryroute) track 1
Questions for the above:
My concern about the above is that there might be a flap and thr route will jump between backup route and primary route.
How do I tell the ip sla to to experience 3 failures before using the back up route?
To confirm the operation above so that I understand it correctly:
When the icmp fails, the router will use the backup route, while its using the back up route, the router keeps trying to send an icmp via primary route till it come back up, when it comes back up it fails back over to the primary route, is this the correct understanding?
The second ip sla
This service providers is a bit more strict about what they allow, we could not use and icmp echo request for this one, instead they asked to check if we can make an ftp connetion, the below will try and make a connection to the destination via port 21, if it cant make a connection(i know this is not a true test as there might be a problem with the server, but they have arrused us that there is secondary server that will take over should the primary fail) then we must failover like to a less reliable route.
ip sla monitor 2
type tcpConnect dest-ipaddr 196.xxx.xxx.xxx dest-port 21 source-ipaddr 10.xxx.xxx.xxx control disable
timeout 10000
frequency 300
ip sla monitor reaction-configuration 2 react connectionLoss threshold-type immediate action-type trapOnly
ip sla monitor schedule 2 life forever start-time now
track 2 rtr 2 state
ip route 196.xxx.xxx.xxx 255.255.255.255 10.xxx.xxx.xxx 5 name RouteItouchFtp(backuproute)
More reliable route
ip route 196.xxx.xxx.xxx 255.255.255.255 10.xxx.xxx.xxx name RouteItouchFtp(primaryroute) track 2
My concern about the above is that there might be a flap and the route will jump between backup route and primary route.
When the "ftp" connection fails, the router will use the backup route, while its using the back up route, the router keeps trying to make a "ftp" via primary route till it come back up, when it comes back up it fails back over to the primary route, is this the correct understanding?
I would like to send some kind of notification on when the router failovers to the back up route and when the router failover back to the primary route, with snmp trap which will get send to our NMS and notify us, if there is another way of notifications to be sent I would be keen to hear im sure one could do an snmp query.
Thanks in advance for any feedback or suggestions on how I can tune the above.
08-27-2013 10:34 PM
Your understanding is correct. As far as flapping, the best way I know to control that is a longer frequency setting. I don't believe there is a delay or dampening feature.
As far as alerting, I believe you will need something that can monitor the syslog and alert you when the particular ip sla syslog messages occur. I dint know of any ip sla snmp mibs. Alternatively, you could have your monitoring software alert you at a low threshold if traffic is going across the second internet connection, assuming it's typically not in use.
Mike
Sent from Cisco Technical Support Android App
