IP SLA ROUTE PROBLEM VRF
dmbnex
Hi All,
Im trying to get a very basic operation of ip sla with reachibility tracking to trigger route decision between two links.
Link 1 - Primary ISP vlan201- is a dhcp link - I need to be able to track an address on internet
Link 2 - Backup LTE link - vlan31 - static ip addressing
both links are terminated in a vrf "inet", there is aslo basic bgp in use locally on the router
what happens is that ip sla comes up with default gw over Link1 but when it goes down the default route is not removed
when I manually remove the default route ip route vrf inet 0.0.0.0 0.0.0.0 Vlan201 dhcp 251 the link 2 route takes over, enabling the link 1 does nothing and when manually pinging the 1.1.1.1 it does not answer when it should.
I have tried removing interface from primary route without it helping.
it may seem that bgp has something to do with this but I'm no sure
ip sla configuration:
track 1 ip sla 1 reachability
ip sla 1
icmp-echo 1.1.1.1 source-interface Vlan201
vrf inet
frequency 15
ip route vrf inet 0.0.0.0 0.0.0.0 10.11.12.2 253
interface Vlan201
vrf forwarding inet
ip dhcp client route track 1
ip address dhcp
end
bgp config:
address-family ipv4 vrf inet
redistribute connected
redistribute static
default-information originate
exit-address-family
vrf:
vrf definition inet
rd 65000:1
route-target export 65000:1
route-target import 65000:1
route-target import 65000:2
address-family ipv4
exit-address-family
Have you guys seen same behavior, or am I just blind and cant see the obvious in front of me?
Equipment in use is Cisco ISR C1100 router with IOS-XE 17.6.5
dmbnex
Hi again,
After moving ip sla to global, importing routes to/from vrf/global this worked with both ip sla tracking and route failover from another vrf.
I will probably use some kind of firewall with policy based routing/probe to achieve this as Cisco is way to unpredictable for me as ip sla sometimes works and sometime does not(even i global)
23 Replies 23
ip route vrf inet 1.1.1.1 255.255.255.255 Vlan201 dhcp permanent
I already have this under the ip sla statement, what are you trying to explain her?
How will this help to force the tracking to remove/add the routes?
making it stick if interface goes down?
in my testing I just disabled the remote side of 1.1.1.1 so interface vl201 stayed UP regardless
OK, remove the
ping 1.1.1.1 are the ping success or not ?( use ping with VRF aware )
OK, remove the
ok, I have tried this. When the sla is UP(to begin with) it works fine, when I bring down 1.1.1.1 manually and track 1 goes down the secondary route is not taking over, I remove it and reenable vl201 and 1.1.1.1, it will not respond to icmp as somehow interface prevents it from passing traffic even when it should.
when tracking is removed from interface and route, all works as it should
I dont have access to the lab today so Im unable to provide testing results
I have time to run lab and you can see immediate after I add static route with permanent the track change from Down to UP.
do this and your floating static route will run fine.
Hi and thank you taking time and testing this but,
it seems that permanent route is only available for static routes and not for dhcp:
router(config)#ip route vrf inet 1.1.1.1 255.255.255.255 vl201 ?
<1-255> Distance metric for this route
A.B.C.D Forwarding router's address
dhcp Default Gateway obtained from DHCP
multicast multicast route
name Specify name of the next hop
permanent permanent route
tag Set tag for this route
track Install route depending on tracked item
<cr> <cr>
router(config)#ip route vrf inet 1.1.1.1 255.255.255.255 vl201 dhcp ?
ip route vrf inet 1.1.1.1 255.255.255.255 vl201 permanent
% For VPN or topology routes, must specify a next hop IP address if not a point-to-point interface
it accepts, more longer route but it's not permanent and will not work:
*Mar 17 23:32:52.772: %TRACK-6-STATE: 1 ip sla 1 reachability Up -> Down
router#sh ip route vrf inet
Routing Table: inet
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, m - OMP
n - NAT, Ni - NAT inside, No - NAT outside, Nd - NAT DIA
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
H - NHRP, G - NHRP registered, g - NHRP registration summary
o - ODR, P - periodic downloaded static route, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
& - replicated local route overrides by connected
Gateway of last resort is 10.10.201.1 to network 0.0.0.0
S* 0.0.0.0/0 [251/0] via 10.10.201.1
10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C 10.10.201.0/24 is directly connected, Vlan201
S 10.10.201.1/32 [251/0] via 10.10.201.1, Vlan201
L 10.10.201.36/32 is directly connected, Vlan201
172.24.0.0/16 is variably subnetted, 4 subnets, 2 masks
C 172.24.16.8/29 is directly connected, Vlan31
L 172.24.16.9/32 is directly connected, Vlan31
router#
router#sh ip route vrf inet track-table
ip route vrf inet 0.0.0.0 0.0.0.0 10.10.201.1 251 track 1 state is [down]
ip route vrf inet 1.1.1.1 255.255.255.255 Vlan201 10.10.201.1 250 track 1 state is [down]
We need permanent with static here
Other solution will make route to 1.1.1.1 always up
I will check how we can solve this issue of permanent and dhcp in static route.
Hello
Your iplsa /route track configuration is okay, but the conditional routing will ONLY work IF the tracked ip address is not reachable via the default route, as when tracked ip fails the ISP1 static default will be removed and the ISP2 default takes over, however when the tracked ip is again reachable the ISP1 primary default won’t be re-entered into the route table as it doesn’t have a specific route to the tracked ip.
Additionally another problem may arise with flapping of the two defaults if your tracked ip becomes reachable via ISP 2 as such ip sla will come up and then the primary default will be installed then fail, with this continuously repeating
So as @MHM Cisco World  shows if you have a specific route to that tracked ip then the conditional failover should work,
Kind Regards
Paul
@paul driver wrote:
Hello
Hi Paul and thanks for time to explain. I understand what you mean by the tracking not being able to reach the destination when there is not default route.
Im not sure this is completely correct as sla is explicitly set up to probe an address with the source interface facing ISP1
anyway, as I replied above, it does not allow me to set a dhcp permanent route
hello
Its not required tbh , try the following:
ip route  vrf inet 1.1.1.1 255.255.255.255 vlan 201
or
ip route  vrf inet 1.1.1.1 255.255.255.255 vlan 201  x.x.x.x < next hop ip> - Preferred as the router wont arp for the route
The sla probe is only polling sourced from vlan 201, as long as the tracked ip can be reached (via isp1 or isp2) it does not care
Kind Regards
Paul
@paul driver wrote:
hello
or
I already have,
ok, that makes sense
I have now tried the lab outside of the vrf configuration and with static 1.1.1.1 route it works as intended, thanks
this raises the question if this will work inside a vrf, I recond I would need to use dhcp route for 1.1.1.1
I will be giving this a try this weekend and report back
Hello
It should make difference in/out of a vrf , you could try using a basic ipv4 ip vrf instead of the definition vrf you currently have running?
Regards the static route pertaining to the tracked route, Your next-hop ip address shouldn't really change, so you could specify it in the static as in my previous post.
Kind Regards
Paul
the gateway/ip has change on me before and I really cannot rely on it staying same. It also happens that gateway is up but the something does not route correctly
I could try tracking with state instead of reachibility with both 1.1.1.1 and my def.gateway if one of two fails then the condition is true but that would be next if I get vrf-aware ip sla working.
I run lab and spent 1 hours, there is no solution for track under interface and DHCP with VRF aware.
but I solve the issue without any track
under the dhcp interface use the below config
ip dhcp client request route
ip dhcp client default-route distance <x>
ip add dhcp
when the router get IP from the DHCP server it will add automatic default route toward the default gw receive from dhcp server and with distance we can specify with commands above
