IP SLA's
CSCO12093326
I have looked in multiple areas online with still no firm understanding of the not command in the tracking of IP SLA's. I am working a failover solution from a Cellular interface 0/1/0 to take over if the primary gig0/1 fails. However the guy before me had these statements below and I am curious as to what the NOT means after the object 1 and 2. Obviously it negates the operation but could someone provide an example so I can better understand it. Also if you can look at the routes that are in there to tell me what you think the guy before me was thinking if possible. Thanks in advance for anything you can provide.
track 1 ip sla 1 reachability
track 2 interface Tunnel0 line-protocol
track 101 list boolean and
object 1 not
track 202 list boolean and
object 1 not
object 2 not
delay down 10 up 20
ip sla 1
icmp-echo 206.253.180.250  source-interface GigabitEthernet0/0
frequency 10
ip sla schedule 1 life forever start-time now
ip route 10.200.200.204 255.255.255.255 Cellular0/1/0 235 track 101
ip route 10.250.0.0 255.255.0.0 Tunnel0 235 track 101
ip route 172.17.17.0 255.255.255.0 Tunnel0 235 track 101
ip route 172.18.18.0 255.255.255.0 Tunnel0 235 track 101
ip route 172.31.1.0 255.255.255.0 Tunnel0 235 track 101
ip route 206.253.xxx.0 255.255.255.0 Tunnel0 235 track 101
ip route 206.253.xxx.0 255.255.255.192 Tunnel0 235 track 101
ip route 206.253.xxx.128 255.255.255.192 Tunnel0 235 track 101
ip route 10.250.0.0 255.255.0.0 Cellular0/1/0 240 track 202
ip route 172.17.17.0 255.255.255.0 Cellular0/1/0 240 track 202
ip route 172.18.18.0 255.255.255.0 Cellular0/1/0 240 track 202
ip route 172.31.1.0 255.255.255.0 Cellular0/1/0 240 track 202
ip route 206.253.xxx.0 255.255.255.0 Cellular0/1/0 240 track 202
ip route 206.253.xxx.0 255.255.255.192 Cellular0/1/0 240 track 202
ip route 206.253.xxx.128 255.255.255.192 Cellular0/1/0 240 track 202
ip route 12.21.xxx.0 255.255.255.0 Cellular0/1/0 track 202
ip route 66.xxx.25.0 255.255.255.0 Cellular0/1/0 track 202
ip route 10.200.200.202 255.255.255.255 Cellular0/1/0
ip route 63.235.xxx.195 255.255.255.255 Cellular0/1/0
ip route 67.130.xxx.54 255.255.255.255 Cellular0/1/0
ip route 206.253.xxx.250 255.255.255.255 GigabitEthernet0/1 220
ip route 206.253.xxx.250 255.255.255.255 Null0 230
ip tacacs source-interface GigabitEthernet0/0
cadet alain
this route will be installed in RIB if the tracked object 101 is UP
You have  this:
object 1 not
so tracked object 101 will be UP if object 1 is not UP( so is down)
ip sla 1
frequency 10
object 1 tracks IP sla 1 and so if ping to 206.253.180.250 sourced from G0/0 is down then object 1 will be down
and so object 101 will be UP and the static route will get installed.
second track object:
object 1 not
object 2 not
AND means 202 will be UP if both are UP and down if one or both are down so
object 1 UP and object 2 UP will yield 202 as DOWN
object 1 DOWN and object 2 DOWN will yield 202 UP
object 1 DOWN and object 2 UP will yield 202 DOWN
object 1 UP and object 2 DOWN will yield 202 DOWN
Regards.
Alain
cadet alain
You have  this:
object 1 not
ip sla 1
frequency 10
object 1 not
object 2 not
Regards.
Alain
