Showing results forĀ
Search instead forĀ
Did you mean:Ā
shelley_wang
Beginner
IP-SLA: send more ICMP within each interval
I have a cisco 7600. It will send an icmp request every second. If the icmp response is not received, 3 consecutive icmp requests will be sent. SLA reachability down will be reported after all 4 icmp responses are not received. The following diagram illustrates my goal.
Sender
--------------------------------------- 0 second
-> 0 sec  (1st icmp Request is sent out)
-> 50ms  (no response, send 2nd icmp after timeout)
-> 50ms  (no response, send 3rd icmp after timeout)
-> 50ms  (no response, send 4th icmp after timeout)
    50ms  Report SLA reachability down
--------------------------------------- 1 second
--------------------------------------- 2 second
Question: will the following configuration achieve my goal?
ip sla 100
icmp-echo 10.32.24.1 source-ip 10.32.24.2
timeout 50
frequency 1
ip sla monitor reaction-configuration 100 react timeout threshold-type consecutive 3 action-type triggerOnly
thx,
Shelley
1 REPLY 1
fb_webuser
Frequent Contributor
This config will give you 1 ping every sec. with a 50ms timeout (not 1 ping every 50 ms), and I'm not sure about the react timeout keyword
Posted by WebUser Ahmed Rasmy
