IP Stack not activated on the WAN interface
benthomas
I'm trying to connect two routers (7206 and 2600) via a serial
interface over IP. Currently the serial communicates perfectly via IPX.
I've just confgured ip addresses on both sides with a /30 mask and
encapsulation is PPP but they cannot ping each other. I even tried HDLC
but the IP stack on the interface cannot even open. I have attached the
"show interface" command output of both routers:
2600 Router
Serial1/0 is up, line protocol is up
Hardware is CD2430 in sync mode
Description: LINK TO SAFEX
Internet address is 192.168.15.70/30
MTU 1500 bytes, BW 128 Kbit, DLY 20000 usec,
reliability 255/255, txload 1/255, rxload 5/255
Encapsulation PPP, loopback not set
Keepalive set (10 sec)
DTR is pulsed for 4294967 seconds on reset, Restart-Delay is 541942
secs
LCP Open
Closed: CDPCP
Open: IPXCP
Last input 00:00:01, output 00:00:01, output hang never
Last clearing of "show interface" counters 1w5d
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 4000 bits/sec, 2 packets/sec
5 minute output rate 1000 bits/sec, 3 packets/sec
489253 packets input, 111702134 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0
abort
599055 packets output, 25929293 bytes, 0 underruns
0 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
7206 Router
SAFEX-7200-2#sh int s3/0:10
Serial3/0:10 is up, line protocol is up
Hardware is Multichannel E1
Description: "Market Traders, Tim Gibson #57-03048-00"
Internet address is 192.168.15.69/30
MTU 1500 bytes, BW 64 Kbit, DLY 20000 usec,
Encapsulation PPP, crc 16, CRC 16, Data non-inverted
LCP Open
Open: IPXCP
Last input 00:00:14, output 00:00:00, output hang never
Last clearing of "show interface" counters 10:49:38
Input queue: 0/75/0 (size/max/drops); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/4/16 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
60631 packets input, 3053947 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0* throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
42071 packets output, 13260031 bytes, 0 underruns
no alarm present
Timeslot(s) Used:10, subrate: 64Kb/s, transmit delay is 0 flags
8 Replies 8
thisisshanky
Level 11
Level 11
Can you paste your configs, as well as a show ip route on either ends.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Is it possible that one (or both) routers have configured "no ip routing"?
In addition to the configs I think it would be helpful to post the output of show ip protocol.
Rick
Rick
Rick,
Find attached the output for the relevant show commands:
show version
IOS (tm) C2600 Software (C2600-D-M), Version 12.0(5)T1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Tue 17-Aug-99 13:11 by cmong
Image text-base: 0x80008088, data-base: 0x80859E60
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
MarketTraders uptime is 2 weeks, 2 days, 2 hours, 3 minutes
System returned to ROM by power-on at 12:12:43 CAT Tue Sep 5 2000
System image file is "flash:c2600-d-mz.120-5.T1.bin"
cisco 2610 (MPC860) processor (revision 0x203) with 20480K/4096K bytes of memory
Processor board ID JAD0345028H (4058204952)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
4 Low-speed serial(sync/async) network interface(s)
1 ISDN Basic Rate interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
NB! NB! command show ip protocol RETURNS NOTHING ?????
show protocols
Global values:
Internet Protocol routing is enabled
IPX routing is enabled
Ethernet0/0 is up, line protocol is up
Internet address is 10.100.3.209/28
IPX address is 3435792.0030.94ab.01a0
IPX address is 3435793.0030.94ab.01a0
show ip route
Gateway of last resort is not set
S 196.26.125.0/24 [1/0] via 192.168.15.69
192.168.15.0/30 is subnetted, 1 subnets
C 192.168.15.68 is directly connected, Serial1/0
10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
S 10.3.12.0/22 [1/0] via 192.168.15.69
S 10.3.4.0/22 [1/0] via 192.168.15.69
C 10.100.3.208/28 is directly connected, Ethernet0/0
show ip interface s1/0
Broadcast address is 255.255.255.255
Address determined by setup command
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is enabled
IP fast switching on the same interface is enabled
IP Flow switching is disabled
IP Fast switching turbo vector
IP multicast fast switching is disabled
IP multicast distributed fast switching is disabled
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Bennie
Thanks for posting the additional information. On the 2600 side it looks ok and I do not see anything that looks like a problem. Perhaps you could post similar data from the 7206?
When you do show ipx route do you see any routes on the 2600 that are learned from the 7206? This would be one way of demonstrating that the serial interface was working.
I also wonder if CDP would tell us anything useful? Although I notice that CDPCP is not open and wonder if CDP has been turned off.
Rick
Rick
Rick,
These guys (2600) are connecting and trading fine using IPX.
These are the outputs from the 7200 Router:
SAFEX-7200-2#sh ver
IOS (tm) 7200 Software (C7200-DK2O3S-M), Version 12.0(7)T3, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Thu 03-Jul-03 20:33 by dchih
Image text-base: 0x60008900, data-base: 0x61242000
ROM: System Bootstrap, Version 11.1(13)CA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
BOOTFLASH: 7200 Software (C7200-BOOT-M), Version 11.3(9)T, RELEASE SOFTWARE (fc1)
SAFEX-7200-2 uptime is 21 weeks, 5 hours, 40 minutes
System image file is "slot0:c7200-dk2o3s-mz.120-7.T3"
cisco 7206 (NPE200) processor with 122880K/8192K bytes of memory.
R5000 CPU at 200Mhz, Implementation 35, Rev 2.1, 512KB L2 Cache
6 slot midplane, Version 1.3
Last reset from power-on
Channelized E1, Version 1.0.
Bridging software.
Primary Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
132 Serial network interface(s)
6 Channelized E1/PRI port(s)
Configuration register is 0x102
SAFEX-7200-2#sh ip int s3/0:10
MTU is 1500 bytes
IP Flow switching is enabled
IP Flow switching turbo vector
IP Null turbo vector
IP multicast fast switching is enabled
IP route-cache flags are Fast, Flow
SAFEX-7200-2#sh ip protocol
Routing Protocol is "ospf 26125"
Sending updates every 0 seconds
Invalid after 0 seconds, hold down 0, flushed after 0
Outgoing update filter list for all interfaces is
Incoming update filter list for all interfaces is
Redistributing: connected, static, ospf 26125
Routing for Networks:
10.3.2.0/24
196.26.125.0
Routing Information Sources:
Gateway Distance Last Update
192.168.99.3 110 13w6d
10.3.18.19 110 1d04h
192.168.99.2 110 5w6d
10.3.18.18 110 1d04h
10.3.18.17 110 1d04h
10.3.18.16 110 1d04h
192.168.99.5 110 1d04h
192.168.99.4 110 1d04h
192.168.38.1 110 1d04h
196.26.123.244 110 04:37:17
196.26.123.247 110 03:48:37
196.26.123.246 110 04:37:16
196.26.123.248 110 04:37:16
172.16.1.1 110 1d04h
173.19.2.1 110 20w6d
198.198.196.1 110 1d04h
196.26.125.127 110 1d04h
Distance: (default is 110)
Bennie
Thanks for posting this information. Would you also post the output of show protocol from the 7206?
I notice on the 2600 show interface that CDPCP is closed and on the 7206 that CDPCP is not present. Is CDP disabled on the 7206 interface? If so would it be possible to enable CDP long enough to get the output of show cdp neighbor detail from both routers?
I also notice that on both routers the show interface does not indicate that IPCP is present. It should be present to run IP on the interface. I am puzzled why IPCP is not present. Would you be able to run debug ppp negotiat, shut down the interface, and then no shut the interface, and capture any debug output and post it (at least on the 2600 if you can not do it on the 7206)?
Rick
Rick
Their line become active on an IP level after they have done those commands requested on the 2600. CDP was not enabled on the serial on the 2600.
Many thanks for your assistance.
Tony.henry
Benthomas,
try a "sho ip route 192.168.15.68" the result should be that the subnet is directly connected to s1/0 and s3/0:10 respectively. This proves that IP is running on the interface.
There seems to some disparity in the configs. the safex side has the BW set at 64K whilst market traders has the link at 128K. I think a look at the configs would be in order.
Tony
