IP Unnumbered help
nuno
Hi Guys
I am a beginner - but i hope you can help.
I have two routers,
Router 1 - has 2 serial cards and an ethernet connection. Serial 1 is using ip unnumbered GigabitEthernet0/0 to the ISP, I want to send the traffic from router 2 via serial 2 to this router, to the isp.
I have configured basic routing between the two routers on serial 2 but i dont think its working as they want. Could i do ip unnumbered on router 2 ??
Any ideas ?
jeffrrod
Level 4
Level 4
Dear Nuno,
Thank you for reaching Small Business Support Community.
What are the routers models you attempt to setup on your case scenario?
Thank you for your time and patience,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
Jose Jara
Level 3
Level 3
Hi Nuno,
Can you please clarify a bit more what do you want to achieve? It is not very clear in your post: "i dont think its working as they want".
Do you want to have just Ip connectivity between the two routers? are you going to run a routing protocol between these two routers?
Anyway, in order to obtain reachability you need to add a static route in both routers, like this:
In R1
ip route 2.2.2.2 255.255.255.255 Serial1/0 2.2.2.2
Where 2.2.2.2 is the Ip address of R2
In  R2
ip route 1.1.1.1 255.255.255.255 Serial1/0 1.1.1.1
Where 1.1.1.1 is the Ip address of R1
Best Regards,
Jose.
