IPoE Cisco ADSL 877 ACL prevent traffic
Eddy.Cuevas
Beginner
Beginner
Hello Folks, I need to to setup NAT on IPoE configured router, but traffics which should be permitted are blocked by the ACL. I hope you can help me to find the problem. Thank you
===== Here ACL===================
Extended IP access list NAT_TRAFFIC
10 permit ip 10.0.0.0 0.0.0.255 any (1 match)
20 deny ip any any (60 matches)
=========Here Configuration==========
R1#show running-config
Building configuration...
Current configuration : 3236 bytes
version 12.4
no service pad
hostname R1
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
ip cef
ip name-server 8.8.8.8
ip name-server 8.8.4.4
crypto pki trustpoint TP-self-signed-1126812597
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1126812597
revocation-check none
rsakeypair TP-self-signed-1126812597
crypto pki certificate chain TP-self-signed-1126812597
certificate self-signed 01
3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31313236 38313235 3937301E 170D3032 30333031 30333138
31365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 31323638
31323539 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100C337 5C13AB4C 652EF91E E7C7B964 EA49A0E1 D92F714A D7AB1009 842EB0C6
4BAFE948 0CA2B8D7 3F3C4BE0 22C36A85 5CC65665 C2DC1EEC 2E90D6BC 76FD6756
91DB246D 0EBF1DDE 3B5A95BA ABF3AC57 ED6179AD 3EC8D87F 9FD7AC04 3E7DD45E
3C54EB7E 54563F8C 0F32CDDF B0457544 7009A43D BBE9EACE AFE3945D 93264000
F7010203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
551D1104 1B301982 17796F75 726E616D 652E796F 7572646F 6D61696E 2E636F6D
301F0603 551D2304 18301680 14A205C2 87E520A9 961B3745 72548863 FD4D8572
F4301D06 03551D0E 04160414 A205C287 E520A996 1B374572 548863FD 4D8572F4
300D0609 2A864886 F70D0101 04050003 818100B0 32A2EDC3 EA851A63 5AD58FB4
9D9A52C2 6297A9C3 9A4E0AC9 7DB91620 2598B353 CBD419E4 D201AA70 5A08D6BA
E1D61385 9359862A 19F3674C EDD612B5 63CF9881 6CD02020 C9E9D201 7EA87889
D9CA233A 3B797AA2 03840B32 A2BD59CE EF635E5B 692AC3E5 19EBAF3C E1F079CD
71AF5B4D 8E76423E 62D5D1B8 B305EC3E CF5025
quit
username cisco privilege 15 secret 5 $1$Oh1p$oECZYZFhQgTbuC53K426D.
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
ip address dhcp
ip nat outside
ip virtual-reassembly
no snmp trap link-status
atm route-bridged ip
pvc 8/35
encapsulation aal5snap
interface FastEthernet0
switchport access vlan 2
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 10.0.0.1 255.255.255.0
ip nat inside
ip route 0.0.0.0 0.0.0.0 ATM0.1
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list NAT_TRAFFIC interface ATM0.1 overload
ip access-list extended NAT_TRAFFIC
deny ip any any
no cdp run
control-plane
line con 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
password cisco
login local
transport input telnet
scheduler max-task-time 5000
webvpn context Default_context
ssl authenticate verify all
no inservice
end
1 ACCEPTED SOLUTION
Georg Pauwen
VIP Master VIP Master
VIP Master
I have made a few adjustments (marked in bold) to your config. You don't need an extended access list.
version 12.4
no service pad
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
quit
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip address dhcp
ip nat outside
pvc 8/35
interface Vlan1
ip nat inside
ip route 0.0.0.0 0.0.0.0 ATM0.1 dhcp
ip http server
ip nat inside source route-map ISP interface ATM0.1 overload
access-list 1 permit 10.0.0.0 0.0.0.255
route-map ISP permit 10
match ip address 1
match interface ATM0.1
no cdp run
control-plane
line con 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
password cisco
login local
no inservice
end
2 REPLIES 2
Georg Pauwen
VIP Master
version 12.4
no service pad
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
quit
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip address dhcp
ip nat outside
pvc 8/35
interface Vlan1
ip nat inside
ip http server
match ip address 1
no cdp run
control-plane
line con 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
password cisco
login local
no inservice
end
Georg Pauwen!!! You are awesome and your solution was awesome. I wish you the best in this career. Thank you
