IPSEC GRE - Security Q?
saquib.tandel
I use this template for IPSEC GRE VPN.
Looking for recommendation to secure the router to avoid other traffic then GRE VPN. All other traffic should be blocked.
crypto isakmp key mtt3rvLBO3jCoV50zoE address 192.168.1.2
crypto isakmp policy 10
encr 3des
authentication pre-share
hash sha
crypto ipsec transform-set TS esp-des esp-sha-hmac
crypto map Knight 10 ipsec-isakmp
set transform-set TS
set peer 192.168.1.2
match address 101
crypto ipsec profile IPsecP
interface Serial0
ip address 192.168.1.1 255.255.255.252
access-list 101 permit gre host 192.168.1.1 host 192.168.2.1
interface Tunnel0
ip address 10.1.1.1 255.255.255.252
ip mtu 1300
tunnel source Serial0
tunnel destination 192.168.2.1
tunnel protection ipsec profile IP
ip route 0.0.0.0 0.0.0.0 Serial0
ip route 10.0.0.0 255.0.0.0 Tunnel0
ST
Yes you need 2 lines in the access list per remote peer. You need to permit UDP 500 which is ISAKMP and does the negotiation of encryption keys for the IPSec session. And you need to permit ESP which is what carries the encrypted traffic.
As I read my response I see that I have a logical error in the example that I gave. I reversed the source and destination addresses. I said:
access-list 110 permit udp host 192.168.1.1 host 192.168.2.1 eq 500
access-list  110 permit esp host 192.168.1.1 host 192.168.2.1
and it should be:
access-list 110 permit udp host 192.168.2.1 host 192.168.1.1 eq 500
access-list  110 permit esp host 192.168.2.1 host 192.168.1.1
Rick
Rick
Richard Burts
There are a few inconsistencies in your config that puzzle me.
The crypto key and the crypto map say that your peer is 192.168.1.2, which would be the device connected by your serial interface. But the tunnel destination and access list 101 specify 192.168.2.1. Is that a typo or is that intended?
If you are using the Tunnel Protection Profile then why is there a crypto map in your template?
If you really mean that you want only the GRE VPN traffic to be allowed then I would suggest that you add this to your config:
access-list 110 deny ip any any
interface serial0
ip access-group 110 in
This will deny anything that is not GRE VPN.
Are you sure that there is not any management traffic or anything else that you might want to go through the serial interface?
Rick
Rick
Hi Rick,
Those where typo mistakes.
I would have around 25 IPSEC GRE Tunnels and one management VLAN on the Router.
Routing protocol running on IPSEC GRE tunnels would be OSPF and couple with EIGRP
So I understand from your reply that I need to have two line ACL for each peer.
thanks again.
ST
ST
and it should be:
Rick
Rick
Thank u so much Rick.
You ROCK man !!!!
