IPSec Site to Site with VTI
Huan NG
Hi all,
I'm testing out the configuration for an IPsec VTI Site-to-Site VPN and have successfully initiated an IPsec tunnel connection between two Cisco peers (R1 & R2) as shown below. The Tunnel interface on each router is up and running.
Each router has routes to networks on the other end. However, for some reason, I still can't ping between R3 & R4 (R3 has a default route pointing to R1's F0/1, and R4 has a default route pointing to R2's F0/1).
Any opinion on what's going wrong in the configuration of both peer routers would be much appreciated.
I'm on Cisco Modeling Lab. I confirm that your config is OK. R3 and R4 default route are configured and no more in order to have reachability beteween 13.13.13.0/24 and 24.24.24.0/24.
Best regards
14 Replies 14
Defualt route not force traffic to pass via tunnel
You need to static route using tunnel as egress interface in both R1 abd R2.
MHM
Huan NG
Does it mean I need to set a static route on R3 & R4?
Route needed
R3 and R4 have defualt route
R1 and R2 have defualt route
R1 abd R2 have static route toward R3/R4 IP using tunnel as egress interface
I.e. R1 have static route for R4 using tunnel interface
MHM
M02@rt37
Hello @Huan NG
On R3 and R4 have you got default route configured ?
Best regards
Huan NG
As per screenshot, only dynamic routes (BGP and OSPF) on R1 and R2.
Ok @Huan NG . So you need routing on R3 and R4. Add default route on each of them.
Best regards
Hi M02@rt37
Confirming that R3 has a default route pointing to R1's F0/1, and R4 has a default route pointing to R2's F0/1
But still they can't ping each other, which is strange.
Any other opinions on this?
Hello @Huan NG
@I did yesterday nothing else...nothing more than your configuration.
RIB on R1 ald R2 are the same also...
Best regards
M02@rt37 Thanks for confirming.
One thing I forgot to mention is that I'm testing out this lab on GNS3.
It may be a GNS3 limitation
Best regards
M02@rt37
@Huan NG
Since OSPF is Ok over your IPSec Site to Site/VTI tunnel, you only need default route on R3 and R4.
It is good after that:
On R4 you will see IP ADD of your tunnel as Next hop on hop#2:
Best regards
Huan NG
Hi M02@rt37
This issue solved ?
MHM
Hi, yes it's resolved.
Nothing wrong with config on all routers.
It must be an issue with GNS3 as the lab works fine on Cisco Modeling Lab.
Thanks for following up.
